Addition and subtraction
Results 1 to 7 of 7
    New Jersey
    Default Addition and subtraction
    I don't know how to do that quote thing or I'd post my code in a thread. I started out writing a simple program to increase and decrease a timer based upon button inputs. When I do the increase, everything works great. When I hit the button to do the decrease, instead of adding 50ms, it adds a lot more then that. I don't have a display attached to it so I can't debug it but it's strange. Maybe a fresh set of eyes will be able to find the problem.
    @ DEVICE PIC16F688, INTRC_OSC_NOCLKOUT, WDT_ON, PWRT_OFF, MCLR_OFF, BOD_ON,PROTECT_OFF
    TRISA = %00111011
    TRISC = %00111110
    ANSEL = %00000000
    CMCON0=7
    PULSEOFFDEC VAR PORTC.4 'PULSE OFF DECREASE BUTTON
    PULSEOFFINC VAR PORTC.3 'PULSE OFF INCREASE BUTTON
    RELAY VAR PORTA.2 'RELAY OUTPUT
    PULSEONINC VAR PORTC.1 'PULSE ON INCREASE BUTTON
    PULSEONDEC VAR PORTC.2 'PULSE ON DECREASE BUTTON
    ONOFFBUT VAR PORTC.5 'ONOFFBUTTON
    ONTIME VAR WORD
    OFFTIME VAR WORD
    RELAY=0
    ONTIME=500
    OFFTIME=500
    '------------------------------START OF PROGRAM---------------------------------
    PAUSE 1000
    START1:
    IF ONOFFBUT=1 THEN
    GOTO START1
    RELAY=0
    PAUSE 500
    START:
    '-------------------------PULSEONINCREASE---------------------------------------
    IF PULSEONINC=1 THEN
    ONTIME=(ONTIME+50)
    PULSEONINCPAUSE:
    GOTO PULSEONINCPAUSE
    '-------------------------PULSEONDECREASE---------------------------------------
    IF PULSEONDEC=1 THEN
    ONTIME=(ONTIME-50)
    PULSEONDECPAUSE:
    GOTO PULSEONDECPAUSE
    '-------------------------PULSEOFFINCREASE---------------------------------------
    IF PULSEOFFINC=1 THEN
    OFFTIME=(OFFTIME+50)
    PULSEOFFINCPAUSE:
    GOTO PULSEOFFINCPAUSE
    '-------------------------PULSEOFFDECREASE---------------------------------------
    IF PULSEOFFDEC=1 THEN
    OFFTIME=(OFFTIME-50)
    PULSEOFFDECPAUSE:
    GOTO PULSEOFFDECPAUSE
    '-------------------------ON/OFF BUTTON-----------------------------------------
    IF ONOFFBUT=1 THEN GOTO MAIN_SEQUENCE
    GOTO START
    '------------------------- MAIN SEQUENCE----------------------------------------
    MAIN_SEQUENCE:
    RELAY=1
    PAUSE ONTIME
    RELAY=0
    PAUSE OFFTIME
    IF ONOFFBUT=1 THEN GOTO START1
    GOTO MAIN_SEQUENCE
    Quote Originally Posted by Christopher4187 View Post
    Could be a switch debouncing problem.
    Every time you hit a button, whether you realize it or not, the switch bounces on/off a bunch of times for a few ms. So, in that nice tight loop you got that detects a switch press, the code sees the press, changes the time, then right away sees the switch not pressed and jumps back to the main loop, but the switch is still bouncing, so it jumps to the time changing bit, and so on and so on...
    Try putting a simple 'PAUSE 10' every time you detect a switch has been pressed and see what happens. If that doesn't work, try 'PAUSE 50' and try again.
    Try this bit instead:
    TRISA = %00111011 : TRISC = %00111110 : ANSEL = %00000000 : CMCON0=7
    ONTIME VAR WORD : OFFTIME VAR WORD : RELAY=0 : ONTIME=500 : OFFTIME=500
    PAUSE 1000
    START1: IF ONOFFBUT=1 THEN START1
    RELAY=0 : PAUSE 500
    START:
    ONTIME=(ONTIME+50) : pause 50
    PULSEONINCPAUSE: IF PULSEONINC=1 THEN PULSEONINCPAUSE
    ONTIME=(ONTIME-50) : pause 50
    PULSEONDECPAUSE: IF PULSEONINC=1 THEN PULSEONDECPAUSE
    OFFTIME=(OFFTIME+50) : pause 50
    PULSEOFFINCPAUSE: IF PULSEOFFINC=1 THEN PULSEOFFINCPAUSE
    OFFTIME=(OFFTIME-50) : pause 50
    PULSEOFFDECPAUSE: IF PULSEOFFINC=1 THEN PULSEOFFDECPAUSE
    IF ONOFFBUT=1 THEN pause 50 : goto MAIN_SEQUENCE
    GOTO START
    MAIN_SEQUENCE:
    RELAY=1 : PAUSE ONTIME : RELAY=0 : PAUSE OFFTIME
    GOTO MAIN_SEQUENCE
    Bombay, India
    to quote, use the word quote enlosed in square brackets and end the quote with /quote in square brackets. Same applies for code.
    When I do the increase, everything works great. When I hit the button to do the decrease, instead of adding 50ms, it adds a lot more then that. Maybe a fresh set of eyes will be able to find the problem.
    How true, See the highlights
    ONTIME=(ONTIME-50)
    PULSEONDECPAUSE:
    and here
    PULSEOFFDECPAUSE:
    Good luck
    JF
    Default Also . . .
    Never mind . . .
    New Jersey
    Thanks Jerson! Sometimes the copy and paste function coupled with no sleep can be a real problem! But, you've helped me once again!
    DOH!!!!
    Missed that myself...and I was looking for it!
    Bombay, India
    My pleasure
    JF
  1. Mathematical Precedence
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 21:44
