Setting I/O ports on 16f629
Results 1 to 4 of 4
    Jan 2008
    Default Setting I/O ports on 16f629
    I have been programming a 16f876 for various control/signal generation applications for years using the TRISA=? line to set the ports to input or output.
    I was hoping to use a smaller (8 pin) chip such as 16F629 to generate a asymmetrical squarewave to regulate a clock but the datasheet is set out very differently to the 876.
    Does anyone know if I can use similar code to set the ports, and if not how is it done?
    thanks.
    Hi Optech. The command you're looking for is TRISIO. Use it just as you would TRISA. The 1's are inputs, 0's are outputs.
    CMCON = 7 'comparators off
    trisio = %11111111 'set all as inputs
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device
    Quote Originally Posted by Optech View Post
    thanks.
    16F629?
    Maybe a 12F629...
    Yes, they are practically the same, but different.
    The PBP manual explains the difference between Ports and GPIO's, TRISIO, etc.
    Jan 2008
    Red face
    Thanks for the info. I have now found the relevant section in the pbp manual although it refers to the 12f675. Also skimask, you were right it is 12f629 - just a typo - or brainfade - not quite sure which...
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. Replies: 4
    Last Post: - 17th April 2009, 09:56
  3. RA6 & RA7 I/O setting on the 16F88
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 20:32
  4. Setting Up Adc Ports
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 04:04
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
