16F628A has been running stable for 10 days now.(Tried doing all sorts of things to make it reset, but its immunity is really good).
So i guess the only solution is to stick with the 16F628A . . .
My problem is still very much alive.
I had turned off the clock for over a month.
Now the clock "locks up" within 48 hours.
It has locked up twice at 7 hours , 14 minutes (7:14).
The mux routine works fine but the ISR just stops updating timing registers.
(The varibles that handle this are bres_hi ,bres_mid ,bres_lo.)
(uC is 16F628A and TMR0 used ot keep time)
I'm still thinking it's related to voltage.
The device is being powered by 3.6V
But the 16F84A is only specified to work down to 4.5V
In post #3 you said the datasheet specifies 2.0V
But that's only for the 16LF84A
Edit: Doh! You're using the 628 now. Nevermind.
shahidali55,
Do you have an updated program?
I tried to compile the program from post#1, but it has too many errors.
It also has the pushbuttons on the same pins as the segments, and ASM opcodes in column 1.
Hello Darrel,
As you suggested in post 2, the battery now charges from output from the 5v regulator (through a diode and a 2.2k resistor). The voltage at the PIC never rises above 4.6v. I tested this system with a 20v DC supply and the voltage at the pic pins is still at 4.63 volts (after 48 hours of running).
I have attached a copy of the file with the required include (Instant interrupts) as a zip archive.
The pushbuttons are not a concern now since the primary function of the device itself
(i.e. keeping time) is not met.
Is ASM opcodes in column 1 bad ?
I don't understand why you've modified DT_INTS-14 like that. There's no need.
I also don't like modified versions being posted on the Internet. Somebody will download it, it won't work, and then they'll blame me.
Yes! Very BAD!Is ASM opcodes in column 1 bad ?
ONLY Labels can go in the first column of ASM code.
This applies to lines using the @ sign too. There must be a space after the @. (unless it's a label)
With opcodes in column 1, the program won't compile. So that can't be the program you are currently running in the chip.
Strange . . .
Compiles fine for me.
I have corrected the OPCODE in column 1 errors and attached another copy of the file.
Sorry for modifying DT_INTS-14 , it it your work and i respect that. I modified it in my frustating attempts to correct the resetting and locking up of the chip.
(still getting 3 warnings though)
