I don't have any problem with what you're talking about, with 2.50a anyways. But quite frankly, I just avoid it altogether by just making the 'middle' of the If/Then another routine.
I've had some programs (one in particular), over 4300 lines long (and that's compacted with a lot of colons like I do often, uncompacted, figure roughly 13,000+ lines). Never had a problem with the amount of code inside of an If/Then, Select Case, While/Wend, or otherwise.
You tend to forget things like RETURN after a GOSUB, or maybe you RETURN from somewhere that you had GOTO'd instead of GOSUB'd. Keep that in mind. I just fixed a buried GOSUB (one of the drawbacks of 'compacting' source code) that would only show up after the loop went thru itself 32 times and ended up causing a stack overflow which killed my entire OS on the one project. I've been fighting it for over 6 months now.
And paging really isn't so much of an issue, moreso with 18F series PICs, and even moreso with PBP for the last few years.
