Barcode reader with PIC16f877A ?
Results 1 to 19 of 19
    Default Barcode reader with PIC16f877A ?
    Hi all,
    I need your help in attendance registration project : I decide to register my students attendance automatically where each student has ID card with he's own number printed in barcode format with 11 digits like this "120061235" when we scaned it.
    I read alot about barcode reader ps/2 protocol and know how it works and how i can interface with PIC16f877a , but i don't where is the problem I don't know how to display this ID number on an LCD for example
    I use the interrupt to get clock
    please anyone have an idea how to read barcode reader and display on LCD ?
    here is my code:
    Include "Modedefs.Bas"
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTD 'LCD register select port
    DEFINE LCD_RSBIT 2 'LCD register select bit
    DEFINE LCD_EREG PORTD 'LCD enable port
    DEFINE LCD_EBIT 3 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 4 'Number lines on LCD
    DEFINE OSC 4 ' We're using a 4 MHz oscillator
    Clr CON 1 ' Serial LCD command to clear LCD
    LINE1 CON 128 ' Line #1 of serial LCD
    LINE2 CON 192 ' Line #2 of serial LCD
    LINE3 CON 148 ' Line #3 of serial LCD
    LINE4 CON 212 ' Line #4 of serial LCD
    Ins CON 254 ' Instruction for LCD command-mode
    symbol SCL = PORTC.3 ' I2C CLOCK pin
    symbol SDA = PORTC.4 ' I2C DATA pin
    symbol clock_barcode=portb.0
    symbol data_barcode=portb.1
    input clock_barcode
    input data_barcode
    output portd.1
    symbol but1=portb.2
    input but1
    portd.1=0
    ON INTERRUPT GOTO reg_id
    OPTION_REG = %00000101 ; falling edge of clock
    pause 2000
    INTCON = %10010000 ' Enable RB0 interrupt
    Addr Var byte ' 8-bit memory address in EEPROM
    EE_ByteOut Var Byte ' Variable whose value is to be stored to EEPROM
    EE_ByteIn Var Byte ' Variable for storing the value read from EEPROM
    ID var bit[250]
    char var byte
    countstep var byte
    counter var byte
    counter=0
    TRISD = 0 ' Port D is output
    EE_ByteOut=0
    lcdout Ins,clr,INS,Line1,"Please Ins. ID card"
    if but1=0 then
    lcdout ins,clr,ins,line1,#counter,ins,line2
    pause 3000
    for countstep=0 to counter
    lcdout #id[countstep]
    pause 2000
    next
    counter=0
    goto main ' Remain in loop
    DISABLE ' Disable interrupts in handler
    reg_id:
    if clock_barcode=0 then ; test falling edge
    id[counter]=data_barcode
    counter=counter+1
    portd.1=data_barcode ' Turn on LED when interrupted
    intcon.1=0 ; reset int
    RESUME ' Return to main program
    ENABLE ' Enable interrupts after handler
    Quote Originally Posted by iugmoh View Post
    A bit contradictory, dontcha think?
    Anywhos...
    Usually, I put my On Interrupt near the beginning of a program, and skip over it into my main program. Some say it's good practice, others say they don't care, and still others say it straightens out execution sometimes. I don't know, I just know it works for me.
    So, assuming you really have a good handle on your hardware and how the barcode scanner actually works, then this little bit of a rewrite should work for you.
    (yes it's all crammed together, that's just the way I roll, you can reformat it all you want)
    <-----LCD & Other DEFINES.....
    clr con 1 : line1 con 128 : line2 con 192 : line3 con 148 : line4 con 212
    ins con 254 : scl var portc.3 : sda var portc.4 : clock_barcode var portb.0
    data_barcode var portb.1 : input clock_barcode : input data_barcode
    output portd.1 : but1 var portb.2 : input but1 : portd.1 = 0 : option_reg = 5
    pause 2000 : intcon = $90 : addr var byte : char var byte
    ee_byteout var byte : ee_bytein var byte : id var bit[250]
    countstep var byte : counter var byte : counter = 0 : trisd = 0 : ee_byteout = 0
    On Interrupt Goto reg_id
    goto mainloop
    reg_id:
    intcon.1 = 0
    counter=counter+1 : portd.1=data_barcode
    ENABLE ' Enable interrupts after handler[/QUOTE]
    mainloop:     lcdout Ins,clr,Line1,"Please Ins. ID card"
    if but1=0 then
        lcdout ins,clr,line1,#counter,ins,line2 : pause 3000
        for countstep=0 to counter : lcdout #id[countstep] : pause 2000 : next
        counter=0
    And it looks to me as if the whole code isn't here...
    Default thank you for your reply
    Thank you for your reply and your information, i will try to change my code now and see if it's working.
    Default after code modifications
    I modify my code, and it's more stable and better than previous which give me the number of bits were scanned counter=96 but previous it's not the same,
    Here is my code after modifications
    symbol clock_barcode=portb.0 ; clock of barcode reader ps/2
    symbol data_barcode=portb.1 ; data of barcode reader ps/2
    symbol but1=portb.2
    ID var bit[250]
    char var byte
    countstep var byte
    counter var byte
    input clock_barcode
    input data_barcode
    output portd.1
    input but1
    counter=0
    pause 2000 ; time for lcd to turn on
    ;;;;;;; interrupt service routine
    reg_id:
    counter=counter+1
    if but1=0 then
    lcdout ins,clr,ins,line1,#counter,ins,line2 : pause 3000
    counter=0
    please if one can tell me if my code is true or not ,which it's collect data from barcode reader ps/2 every falling edge trigger of clock which this will tell the microcontroller interrupt service routine to save the data bit on this edge!
    One of the problems you're going to have is the fact that you won't get an interrupt in the middle of a statement.
    For instance,
    Pause 3000...
    The On Interrupt won't trigger for at least 3 seconds.
    (However, instead of Pause 3000, you can use:
    for x = 1 to 300 : pauseus 10 : next x...at least then the PIC will check for an interrupt every 10 microseconds)
    Any LCDOUT command won't let an On Interrupt trigger during the execution of the LCDOUT command, which can take a few milliseconds, an eternity when dealing with fast signals.
    In general, all interrupts are checked BEFORE or AFTER every statement (I don't remember which). So, if you're executing a single command, an ON INTERRUPT won't happen in the middle of it.
    Either recode your program to keep anything in the main loop from holding up an interrupt or think about researching and switching over to DT's Instant Interrupts.
    [QUOTE=skimask;49542]One of the problems you're going to have is the fact that you won't get an interrupt in the middle of a statement.
    QUOTE]
    oky I avoid this problem by placing If statement " If but1=0 " which all commands inside this if statement will not execute untill I press the button placed on portb.2
    but I want to ask if there is something wrong in my code
  1. PS/2 barcode reader to RS232 port - need help
    By phoenix_1 in forum Schematics
    Last Post: - 28th May 2008, 06:35
  2. Barcode reader Problem ?
    By iugmoh in forum General
    Last Post: - 18th February 2008, 21:25
  3. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 07:23
  4. Proximity Card Reader
    By Sphere in forum mel PIC BASIC Pro
    Last Post: - 6th November 2005, 15:43
  5. Smart card reader with PIC16F84A
    By bangunprayogi in forum Serial
    Last Post: - 12th August 2005, 11:36
