how to shrink code
Results 1 to 13 of 13
    Quote Originally Posted by Peter1960 View Post
    a minor oversight !
    The demo PIC had 8k,
    final PIC ONLY 4k !
    Suggestions to shrink code, please !
    I have already used ASM/ENDASM where possible,
    have used minimal GoSubs,
    I started with 7996 and am down to 5100, only 1100 bytes to go !
    any other suggestions ?
    kindest regards
    Which PIC?
    If it's a 16F series, you can probably mess with the variables a bit.
    Figure out which variable you 'access' the most and ensure it's forced into BANK 0.
    For that matter, let's see the code.
    You'll probably get a 1000 ideas on how to shrink the code.
    Jan 2006
    Istanbul
    Also,
    1. If you have small subroutines and/or small loops , keep them at the beginning.
    Also,
    2. if you are comparing a byte variable to a word variable, make sure, you compare the byte variable to the lowbyte of the word variable.
    Ex:
    A var byte
    B var word
    Instead of
    IF A = B THEN Home
    use,
    IF A = B.LowByte THEN Home
    Also,
    3. If you have HIGH and LOW commands, make them direct access to PORT register.
    Ex:
    Instead of
    HIGH PinA
    Use,
    PinA = 1
    Feb 2003
    Salt Lake City, Utah USA
    See Cliff Griffin's hints here
    http://www.rcfaq.com/PIC/optimize.htm
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2007
    USA, CA
    If minimal code size is the goal, then PBP is a LOT of work.
    Reducing gosubs is not always the best rule, unless you are getting rid of the subs that were only added to make the code more "readable". If you can insert a few subroutines to eliminate duplicate code, they are very helpful.
    One thing to do is eliminate as many built-in basic commands as possible. For instance, hserout is very inefficient. You can manually load your values into the TXreg and save a lot of space. The ADCIN command is probably even worse.
    Feb 2005
    Smile
    Hi and thanks everyone.
    Using a combination of Lookup and assembler
    the code is now 3768 !!!! beauty !
    I noticed that lookup can reduce code but can also
    increase code, so be carefull !
    thanks
    kind regards
    Peter
    Pete
    Jan 2006
    Istanbul
    increase code, so be carefull !..
    Peter
    Peter, it depends on the location of the LookUp statement in your program.
    Just do a little experiment by changing its location in the program.
    Sep 2007
    USA, CA
    Quote Originally Posted by sayzer View Post
    A lot also has to do with how many elements you are looking up. It does not pay off until you are looking up more than just a few... 2-3, and it is a waste; a dozen and it saves a lot.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
