Newbie 74hc595 question
Results 1 to 11 of 11
    The 74HC595 also needs a "Latch" signal. (3 pins, clk, data, latch)
    I think it's called RCLK in the datasheets.
    Jan 2008
    First of all, Thanks darren for the quick reply.
    so i need to put an extra pin - can i use porta.2?
    and just take it low and high before and after shifting right?
    Thanks again,
    Shahar
    Quote Originally Posted by manjero View Post
    No problem Shaharn.
    Yes!
    But before you can use any of the PORTA pins, including the ones you have already used, you need to turn off the Analog functions.
    CMCON0 = 7
    ANSEL = 0
    A simple HIGH/LOW toggle of the Latch after shifting will do it. The 595 is a very fast chip.
    But there are more problems too.
        sleep 1000
        Shiftout D1PIN, C1PIN, MSBFIRST,[0]
        goto Main
    sleep 1000 will put the PIC in low power mode for somewhere around 1000 seconds. (16 minutes, 40 seconds)
    sleep 60 would be closer to 1-minute, but it'll only be "somewhere around" a minute, since it uses the Watch Dog Timer..
    PAUSE 60000 ; would be a better approximation, without resorting to Timers.<hr>
    That's going to shift out 8-bits. So 8 of the LED's will turn off at the same time.
    The way you're doing it, you don't really need the shiftout statement in the Main loop.
    First, set the Data pin to 0 before going into the loop.
    Then after each minute toggle the Clock pin once, to shift in a 0.
    Then toggle the Latch Pin, to move the data to the 595's output's.
    <hr>Also, the first ShiftOut's can be combined...
    Shiftout D1PIN, C1PIN, MSBFIRST,[bvar, bvar, bvar, bvar]
    Jan 2008
    Hey DT.
    Thanks again - that was very informative!
    I changed my code to this:
    Include "modedefs.bas" ' Include shift modes
    CMCON0 = 7
    ANSEL = 0
    DPIN var PORTA.0 ' Shift data pin 1
    CPIN var PORTA.1 ' Shift clock pin 1
    LPIN var PORTA.2 ' Latch pin 1
    bvar var BYTE
    bvar = 255
    ' Shift out 8 bits of data onto other pins
    Shiftout DPIN, CPIN, MSBFIRST,[bvar, bvar, bvar, bvar]
    Low DPIN
    pause 5980
    High CPIN
    pause 10
    'Shiftout D1PIN, C1PIN, MSBFIRST,[0]
    LOW CPIN
    Pulsout LPIN,10
    goto Main
    Compiles OK so lets hope :-)
    Jan 2008
    Hello manjero, I think that Darrel missed the fact that you're using an 'F84. You can drop the:-
    CMCON0 = 7
    ANSEL = 0
    The 'F84 doesn't have any analogue inputs to turn off or configure as digital IO. They're always digital IO. In fact, I have 16F84(A) selected, the compiler, (v 2.44), doesn't even recognise CMCON0.
    ... Steve (Yep, another one)
    Quote Originally Posted by scarroll01 View Post
    The upgrade covers that too, only $25.
    Get your now...hurry hurry hurry.
  1. newbie with serial com question...
    Last Post: - 16th December 2006, 06:34
  2. Newbie Question - Info Please
    By ehoskins in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 15:50
  3. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 16:52
  4. Newbie question
    By senojlr in forum General
    Last Post: - 11th April 2006, 22:23
  5. Replies: 4
    Last Post: - 8th September 2005, 16:42
