Newbie 74hc595 question
Results 1 to 11 of 11
    Jan 2008
    Default Newbie 74hc595 question
    Hie
    I'm a newbie in pic programming and i'm trying to build a night lamp with 30 leds. at start they are all supposed to be lit and then after every minute one of them should turn off.
    I built the circuit using 4 74hc595 cascaded and with a pic16f684 i had laying around with a 4 MHZ xtal.
    my question is about the code - if i understand correctly, the code it should look like this:
    Include "modedefs.bas" ' Include shift modes
    D1PIN var PORTA.0 ' Shift data pin 1
    C1PIN var PORTA.1 ' Shift clock pin 1
    bvar var BYTE
    bvar = 255
    ' Shift out 8 bits of data onto other pins
    Shiftout D1PIN, C1PIN, MSBFIRST,[bvar]
    sleep 1000
    Shiftout D1PIN, C1PIN, MSBFIRST,[0]
    goto Main
    Is this ok? im getting the programmer ready now and i just wanted to get some input before i actually program it because its my first project.
    Thanks in advance,
    Shahar Zrihen.
    The 74HC595 also needs a "Latch" signal. (3 pins, clk, data, latch)
    I think it's called RCLK in the datasheets.
    Jan 2008
    First of all, Thanks darren for the quick reply.
    so i need to put an extra pin - can i use porta.2?
    and just take it low and high before and after shifting right?
    Thanks again,
    Shahar
    Quote Originally Posted by manjero View Post
    No problem Shaharn.
    Yes!
    But before you can use any of the PORTA pins, including the ones you have already used, you need to turn off the Analog functions.
    CMCON0 = 7
    ANSEL = 0
    A simple HIGH/LOW toggle of the Latch after shifting will do it. The 595 is a very fast chip.
    But there are more problems too.
        sleep 1000
        goto Main
    sleep 1000 will put the PIC in low power mode for somewhere around 1000 seconds. (16 minutes, 40 seconds)
    sleep 60 would be closer to 1-minute, but it'll only be "somewhere around" a minute, since it uses the Watch Dog Timer..
    PAUSE 60000 ; would be a better approximation, without resorting to Timers.<hr>
    That's going to shift out 8-bits. So 8 of the LED's will turn off at the same time.
    The way you're doing it, you don't really need the shiftout statement in the Main loop.
    First, set the Data pin to 0 before going into the loop.
    Then after each minute toggle the Clock pin once, to shift in a 0.
    Then toggle the Latch Pin, to move the data to the 595's output's.
    <hr>Also, the first ShiftOut's can be combined...
    Shiftout D1PIN, C1PIN, MSBFIRST,[bvar, bvar, bvar, bvar]
    Jan 2008
    Hey DT.
    Thanks again - that was very informative!
    I changed my code to this:
    CMCON0 = 7
    ANSEL = 0
    DPIN var PORTA.0 ' Shift data pin 1
    CPIN var PORTA.1 ' Shift clock pin 1
    LPIN var PORTA.2 ' Latch pin 1
    bvar var BYTE
    bvar = 255
    Shiftout DPIN, CPIN, MSBFIRST,[bvar, bvar, bvar, bvar]
    Low DPIN
    pause 5980
    High CPIN
    pause 10
    'Shiftout D1PIN, C1PIN, MSBFIRST,[0]
    LOW CPIN
    Pulsout LPIN,10
    goto Main
    Compiles OK so lets hope :-)
    Jan 2008
    Hello manjero, I think that Darrel missed the fact that you're using an 'F84. You can drop the:-
    CMCON0 = 7
    ANSEL = 0
    The 'F84 doesn't have any analogue inputs to turn off or configure as digital IO. They're always digital IO. In fact, I have 16F84(A) selected, the compiler, (v 2.44), doesn't even recognise CMCON0.
    ... Steve (Yep, another one)
    the 16F684 does
    [/QUOTE]Hello manjero, I think that Darrel missed the fact that you're using an 'F84. You can drop the:-
    CMCON0 = 7
    ANSEL = 0
    [/QUOTE]
    Jan 2008
    Quote Originally Posted by bbarney View Post
    the 16F684 does
    CMCON0 = 7
    ANSEL = 0
    [/QUOTE][/QUOTE]
    Sorry, it's my failing eyesight. I didn't see the "6" and thought it was a PIC16F84.
    ... Steve
    I only seen the 6 cause I know Darrel doesn't miss anything
    Uht-Oh, I'm getting a reputation.
    I changed my code to this: ...
    That's getting closer, but Wait, there's More.
    The Latch Pin should start out LOW.
    Then after the SHIFTOUT, the data gets latched by toggling it High/Low.
    The pause only adds up to about 6000 (6 seconds).
    For 60 Seconds, you need 60,000.
    And the 595 is a really fast chip. pause 10 and Pulsout aren't needed.
    bvar = 255
    LOW  LPIN       ; Latch Idles LOW
    ' Shift out 32 - 1's to 74HC595's
    HIGH LPIN       ; Latch data to 595's outputs
    LOW  LPIN
    Low DPIN        ; Set Data to 0
        pause 60000 ; Wait 1 minute
        HIGH CPIN   ; clock in a 0
        LOW  CPIN
        LOW  LPIN
    GOTO Main
    hth,
  1. newbie with serial com question...
    Last Post: - 16th December 2006, 05:34
  2. Newbie Question - Info Please
    By ehoskins in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 14:50
  3. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 15:52
  4. Newbie question
    By senojlr in forum General
    Last Post: - 11th April 2006, 21:23
  5. Replies: 4
    Last Post: - 8th September 2005, 15:42
