Frequency Generator
Results 1 to 3 of 3
    Jan 2008
    Smile Frequency Generator
    Hello, my english is not so good but I will try to post for the first time....
    I am trying to make a very stabile frequency generator from 10 Hz to 100 Hz
    and in increments of maximum 0.1 Hz but 0.05 Hz would be great.
    My first idea was to use the 16F872 and it's HPWM output witch
    is from about 1200Hz to 32767 Hz , and divide the output by 300 [lot's of D-Flip Flops].
    The problem is that the PWM output is working in increments of about 100 Hz,
    and 100 Hz / 300 = 0.3Hz resolution......no good.
    Is there a way to get a better resolution by using Asembler, or is using the DDS like
    AD9833 or AD9850 my only option?
    The mesurements from very good frequency meter taken from the HPWM output are :
    9708 Hz
    9803 Hz
    9900 Hz
    10000 Hz
    10100 Hz
    10203 Hz
    10308 Hz
    10415 Hz
    10526 Hz
    10638 Hz
    and the code is:
    device=16F872
    DECLARE XTAL=4
    CONFIG xt_OSC , WDT_OFF , PWRTE_ON , BODEN_ON , LVP_OFF , WRTE_OFF , CP_OFF , DEBUG_OFF
    DECLARE BOOTLOADER = OFF
    DECLARE PORTB_PULLUPS = OFF ' Disable PORTB pullup resistors
    DECLARE WATCHDOG = ON
    DECLARE REMARKS ON
    DECLARE ICD = OFF
    DECLARE LCD_DTPIN = PORTA.0
    DECLARE LCD_RSPIN = PORTA.5
    DECLARE LCD_ENPIN = PORTa.4
    DECLARE LCD_INTERFACE = 4 ' 4-bit Interface
    DECLARE LCD_LINES = 2
    ALL_DIGITAL = TRUE
    SYMBOL PressUp = PORTB.7
    SYMBOL PressDOWN = PORTB.6
    DIM freq AS word
    Dim freq_OUT as word
    dim freq_in_END as word
    DECLARE CCP1_PIN PORTC.2 ' Select HPWM port and bit for CCP1
    'debounce
    DIM UP AS BYTE '
    DIM DN AS BYTE '
    UP = 0
    DN = 0
    freq_in_END=10000
    freq_OUT = 10000
    freq=10000
    TRISA = %00000000
    TRISB = %11000000
    TRISC = %00000000
    HELLO: PRINT AT 1,1,"Freq. generator"
    DELAYMS 1000
    CLS
    BEGINING:
    Button PressUp,1,255,0,UP,1,A_freq_UP
    Button PressDOWN,1,255,0,DN,1,A_freq_DOWN
    If freq > freq_in_END then
    freq_OUT = freq-1
    If freq < freq_in_END then
    freq_OUT = freq+1
    HPWM 1,127,freq_OUT
    PRINT AT 1,1,"Freq. is:",dec freq,"Hz"
    delayms 100
    freq = freq_OUT
    GOTO BEGINING
    A_freq_UP: freq_in_END = freq+10
    GOTO BEGINING
    A_freq_DOWN: freq_in_END = freq-10
    GOTO BEGINING
    Thank You
    ExYu
    ExYu,
    It looks like you are using Proton.
    The forum for that compiler is at ...
    http://www.picbasic.org/forum/
    This forum is for PicBasic Pro from meLabs.
    Jan 2008
    Ops...
    Sory, and thank you
    ExYu
  1. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  2. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  3. HPWM10 Frequency Updating
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 13:30
  4. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
  5. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 01:53
