I think I ran one around 100 ft or so but I used a twisted pair and the DS18B20-PAR. I also use a 1K pull-up and switch a GP transistor to give power to the device when it does its conversion.
I use the DS1620 over several (~10) metres. I found I had to terminate the data and clock lines with a 120 ohm resistor and a 0.1 uF capacitor to ground to prevent ringing on these lines which screwed up the data stream. I also put a 10 uF across the DS1620 power to ground pins.
I realise the DS1820 is not the same as the DS1620 but the ringing issue may be the same.
HTH
BrianT
