NOPE,
if you use 1 without $FE before, it will try to print ASCII decimal character 1, same for $0F. If you want to mask you data with asterix, just use "*" in your lcdout and forget the #key.
MAybe you could find some tips in the following
http://www.picbasic.co.uk/forum/show...mbination+gate
1)I tried to include Keypad.bas and tried to compile however it throws an error for the first line i.e. keypad routine as syntax error. If I remove it throws too many errors! in assembler. Is it not necessary to compile. If I don't compile and compile only gate code it says unable to open keypad.bas
@ if HIGH_SECURITY == 1
LCDOUT $FE, $C4 + ComboPtr, "*" ; print a Mask character
if Key = "*" then Reset
if Key = "#" then Finish
@ endif
The compiler also shows errors for
I tried using diff. combination but to no better effect. Can some one help?
Thank you in advance,
dilpkan
