LCD display not working properly
Results 1 to 15 of 15
    Jun 2006
    Mountain View California
    I didn't see a Chk_KEYPAD subroutine included in your code. Do you have one?
    Jan 2008
    If this is for password entry, do you even WANT to display the characters that are entered? Better to handle it like MS Windows and display asterisks.
    Just a thought,
    ... Steve.
    Nov 2007
    Smile
    Quote Originally Posted by scarroll01 View Post
    Just a thought,
    ... Steve.
    Thanks for replying
    I accept your suggestion ! however how to get the four asterisks in four positions in one line
    Please suggest
    dilpkan
    Nov 2007
    Smile
    Quote Originally Posted by bbazor View Post
    Chk_KEYPAD subroutine has been used at gosub
    The problem is that the four numbers are not displayed at 1st , 2nd , 3rd ,4th positions in one line
    thanks for replying
    dilpkan
    Quote Originally Posted by dilpkan View Post
    thanks for replying
    dilpkan
    Let's analyze one of your LCDOUT statements...
    Lcdout $fe, $c0+1,1,$0f, #key
    LCDOUT - the command
    $fe - send an instruction
    $c0 + 1 - the position
    1 - clear the display which basically resets the display back to square one
    $0f - programmable character
    #key - a variable
    See a problem here?
    Nov 2007
    Smile
    #key - a variable
    See a problem here?
    I deleted "1 " -(clear the display...) and tried the above code using gosub four times for the four diff. positions but the display shows a question mark at 16th position on first line and stops. why?
    please help.
    dilpkan
    please help.
    dilpkan
    Increase the startup pause to 1 second...increase your LCD_commandus and LCD_dataus to higher values, try it again and see what happens.
    NOPE,
    if you use 1 without $FE before, it will try to print ASCII decimal character 1, same for $0F. If you want to mask you data with asterix, just use "*" in your lcdout and forget the #key.
    MAybe you could find some tips in the following
    http://www.picbasic.co.uk/forum/show...mbination+gate
    NOPE,
    Are you saying that:
    LCDOUT $fe , 1 , $80 , "HELLO"
    is different from:
    LCDOUT $fe , 1 , $fe , $80 , "HELLO" ???
    I guess I just never noticed, or tried it.
    Jan 2008
    Finland
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  2. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 06:41
  5. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
