help read Back EMF of DC motor
Results 1 to 10 of 10
    Puerto Rico
    Exclamation help read Back EMF of DC motor
    Hello if son one don this ..
    I need to read Back EMF of DC motor
    My Hobbies is PicBasic PRO
    I would probably use an oscilloscope.
    Or do you mean, have the PIC read it?
    Puerto Rico
    Exclamation
    yes read with the pic
    Quote Originally Posted by jetpr View Post
    Well, I won't say that it can't be done.
    But the thing is ... For any normal "dc motor" circuit, you need to "shunt" any "Back EMF" with reverse biased diodes, because the voltage is outside of the operating range of the PIC. And being "outside" of the PIC's range, it can't read it.
    I'm sure it's possible to create a Test Circuit to measure the effect, but if you just want to try and read it, because it keeps reseting the program. It would be better to use an oscilliscope.
    Puerto Rico
    Exclamation
    my problem is
    I needed to know when the motor begins to rotate
    I - I - I don't have a clue.
    I thought it was a different problem. Sorry.
    Take a look here .
    http://www.romanblack.com/encoder.htm
    hope it helps
    Victor
  1. Replies: 19
    Last Post: - 27th May 2010, 04:56
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. DC motor parameters estimation !
    By iugmoh in forum General
    Last Post: - 6th June 2008, 18:29
  5. Write and Read from eeprom
    Last Post: - 9th June 2007, 15:56
