LCD display remains empty
Results 1 to 14 of 14
    Oct 2003
    holland
    Let us see how you connected everything from the chip to the display.
    Try to adjust the background voltage, may be that is the problem!
    Put a pause of 1 sec. between the declaration and your programm. Maybe the display was not yet setup.
    In a world of german electrons
    I have not told you yet that the LCD's functionality is not proven. I was given it by someone in a waste utilization for free.
    How do I figure out whether it works or not? I was able to make the lcd's points show(two rows, all matrices black). What can I conclude from that?
    Be well - whoever you are.
    selbstdual, If you can see all black pixels then it sounds like the contrast is set too high. How do you have the contrast circuit setup? It should be at minimum a 5k pot between VCC and ground with the center wiper connected to the contrast input pin.
    Dave, does seeing the matrices mean that the display is working at all?
    Perth, Australia
    Try adding these 2 things:
       Define OSC 20
            DEFINE	LCD_DREG PORTB
    		DEFINE	LCD_DBIT 0
    		DEFINE	LCD_RSREG PORTB
    		DEFINE 	LCD_RSBIT 4
    		DEFINE	LCD_EREG PORTB
    		DEFINE	LCD_EBIT 5
    		DEFINE	LCD_BITS 4
    		DEFINE	LCD_LINES 2
    		DEFINE	LCD_COMMANDUS 2000
    		DEFINE	LCD_DATAUS 50
                    PAUSE 100
    Go:
        LCDOUT $FE,1,$FE,2,"Geez"
        Sleep 100
        GOTO Go
    First of all I want to make sure that the lcd is working at all. How do I do that?
    Perth, Australia
    first, make sure that when you apply power, the top line of the LCD displays solid blocks. If this is the case, try the additions i suggested above.
    If this is not the case, you probably need to have a contrast control for the LCD. You need a variable resistor and hook it up like this:
    LCD pin 3
       |   +5v
       ---->\ variable resistor (10k or bigger)
           gnd
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
