To no avail . . .
Results 1 to 6 of 6
    Default To no avail . . .
    Hi Everyone,
    This is my first use of a 12F675, and I used some of Bruces code, to BCD control the time period from a lookup table and it works really well. I am using his code to control LED off time, But I am trying to control on time using IF / THEN loops and the code simply ignores the IF / THEN loop as if it simply said 250. If I substitute a number in the B0 variables place it uses that number. Anyone have an idea why the IF/Then loop has no effect? I have moved it around within the code to no avail.
    Thank You
    JS
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
     PCON = %00000011       ' BOD off, No POR flag set
    DEFINE  NO_CLRWDT 1
        OSCCAL = %1111100   '
        CMCON   = 7	        ' disable analog comparators
        ANSEL   = 0         ' disable A/D module, all digital
        WPU.4 = 0           ' disable weak pull up on GPIO.4
        B0    VAR BYTE
        X     VAR WORD
        Index VAR BYTE
        LED   VAR GPIO.5
        TRISIO = %00011111   ' RA0 to RA3 inputs for DIP switch
        OPTION_REG = %11111111
         IF (GPIO.4 = 1) THEN
      B0 = 2500
      B0 = 250
        Index = GPIO & $0F   ' Read DIP switch AND mask result
        LOOKUP2 Index,[200,300,400,500,600,700,800,900,1000,2000,_
        3000,4000,5000,6000,7000,8000],X
        HIGH LED
        PAUSE b0
        LOW LED
        PAUSE X
    GOTO Main
        POKECODE @$3FF, $50  ' reintroduces osscal correction data
    Wink just a typo ...
    I note :
    B0 var Byte ... and further B0 = 2500 ...
    so, 255 is the maximum possible value for B0
    I note :
    <h2><font color=red> THANKS! that was it !</h2></font color>
    That was a BOZO not a typo
    [QUOTE=Joe S.;49321That was a BOZO not a typo [/QUOTE]
    Glad to see you're happy ...
    Since you're using a 12F675, how much accuracy do you need with the delay?
    If a lot of accuracy isn't needed, how about throwing a pot on a pin and using the POT command for a the delay?
    It would save you 3 pins to do other stuff with at the very least, and you can still scale the delay from a low to a high end with a simple software change.
    Hi Jeremy,
    I might do that, this device only needs to do what it does, but those extra pins could be used for more on time options like 500, 1000, or maybe the pot command might control that.
    JS
