Confused?! Tryingto control a paintball solenoid.
Results 1 to 14 of 14
    Dec 2003
    Wichita KS
    Hello Ieland,
    I>>The problem I am having is when it fire the 3 burst the shots seem to delay. i am trying to achieve maxium rate of fire. Anyone have and ideas?<<
    I do not know what your setup is, I can only guess.
    1. You will need the PIC to have complete control of your firing.
    2. One pin will be connected to your switch... the other pin will control the firing.
    3. Need to have a timer to measure the timing between each of the shots.
    This is just a quicky, and some of it is in psuedo code and C/C++... But the idea is there.
    Trigger var Porta.2
    Sil var Porta.1
    Var Timer;
    Var Counter;
    Counter=0;
    Timer=0;
    Loop:
    Trigger=0; 'does it have pulling resistors?
    if Trigger=1 gosub Fire
    pause 50 'only allow 1 shot every 1/20 of a second
    if Trigger=0 then Timer++
    if Timer>50 Counter=0; 'resets to single shot, this adjusts delay
    goto Loop
    Fire:
    if Counter<8
    Sil=1 'fire the sucker
    pause 5
    Sil=0
    pause 5 'make sure you are not too fast!
    Endif
    if Counter=8
    Counter=6
    while Counter<8
    pause 5
    Sil=0
    pause 5
    Counter++
    Wend
    Counter=7
    Endif
    Counter++
    Ability to Fly:
    Pilots that are Flying:
  1. A logic gate chip with 1 ea XOR and 2 ea AND gates?
    Last Post: - 5th August 2009, 05:29
  2. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  3. HPWM Motor Control
    By hughgoodbody in forum General
    Last Post: - 30th January 2005, 22:41
