I'm a sucker for simplicity.
Try this;
When you press the switch it grounds GPIO.0.Code:GPIO.4 ----/\/\/\---|<|----+5V. LED 10K GPIO.0 --|--/\/\/\---+5V |--switch---GND.
Does this work?Code:@ device pic12F629, intrc_osc_noclkout, wdt_on, mclr_off, protect_off DEFINE OSCCAL_1K 1 DEFINE OSC 4 RELAY VAR GPIO.4 ' relay output Pswitch VAR GPIO.0 ' switch input TRISIO = %00000001 ' GPIO.0 input, rest outputs WPU = 0 ' input pull-ups disabled CMCON = 7 ' disable comparators PAUSE 10 ' POR delay MAIN: RELAY = ! Pswitch ' Relay pin = the opposite of Psiwtch pin GOTO MAIN END
