Pic 12f629
Results 1 to 15 of 15
Thread: Pic 12f629
    Quote Originally Posted by runrite View Post
    Hi There thanks
    I have done just that on the input I have
    100k to ground permanently on GP0
    the switch is wired in this order +5V 10K switch then GP0
    still no luck
    It just does nt want to check the input condition I have a relay conected via a transistor to the output
    This is quite a puzzling problem
    Your answer is just a little bit cryptic...
    Have you gotten the blinky LED thing to work?
    You have a relay connected to the output?
    Does it have a 'flyback diode' connected across the coil?
    Is the same power supply driving the PIC that's driving the relay coil?
    Jan 2008
    Hi there
    Yes 12V to relay and 5V to pic
    flyback diode
    If I change the code I can get the relay to go on and off
    I have used the 16f876's never had a problem like this
    am i not doing something wrong with the configuration in MP Lab
    I am using microcode studio with PBP
    flyback diode
    Maybe try turning off the WDT?
    Try different code, just for grins...
    if pswitch = 1 then relay = 0
    if pswitch = 0 then relay = 1
    Jan 2008
    Hi There thanks will try
    to morrow let you know the outcome
    Jan 2008
    Many thanks it works..
    It is sensing now..
    the relay chatters when I get it on
    Is it to do with the external MCLR
    There is an error message that comes on it says that ICD can not program internal clock and internal MCLR at same time any way to sort it out I have to use the on board clock
    I'm a sucker for simplicity.
    Try this;
    GPIO.4 ----/\/\/\---|<|----+5V.
                        LED
                 10K
    GPIO.0 --|--/\/\/\---+5V
             |--switch---GND.
    When you press the switch it grounds GPIO.0.
    @ device  pic12F629, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
        DEFINE OSCCAL_1K 1
        RELAY VAR GPIO.4   ' relay output
        Pswitch VAR GPIO.0 ' switch input
        TRISIO = %00000001 ' GPIO.0 input, rest outputs
        WPU = 0            ' input pull-ups disabled
        CMCON = 7          ' disable comparators
        PAUSE 10           ' POR delay
    MAIN:
        RELAY = ! Pswitch ' Relay pin = the opposite of Psiwtch pin
        GOTO MAIN
    Does this work?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Switch to ground. Definately the better way to go.
    I might suggest a different Main loop though.
    MAIN:
        IF RELAY = Pswitch THEN
            RELAY = ! Pswitch ' Relay pin = the opposite of Pswitch pin
        PAUSE 20
        GOTO MAIN
    Those pesky R-M-W's
    Jan 2008
    Hi all out there
    The last time I did a 8 pin pic was 10 years ago
    The problem was to do with the weak pull up
    I really want to thank all out there
    Bye for now
    Jan 2006
    Istanbul
    MAIN:
        PAUSE 20
        GOTO MAIN
    Those pesky R-M-W's
    Darrel,
    I just want to learn;
    Is it really a safe way to read the status of an output pin?
    Yes, in fact, from my understanding, it reads the content of the output-latch.
    Quote Originally Posted by sayzer View Post
    Is it safe?
    Well, as far as doing damage, it's perfectly "Safe".
    In fact the chip "reads" the state of the OUTPUT pin, everytime you you change the state of any pin on the same port.
    The only un-safe part, is if you don't take the R-M-W problems into account.
    Can really mess with the program.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. program a pic 12f629
    By cancan in forum General
    Last Post: - 28th April 2008, 16:15
  4. Serial Pic to Pic using HSER
  5. Problem Pic 12f629
    By diegover in forum mel PIC BASIC Pro
    Last Post: - 19th July 2004, 12:51
