Pic 12f629
Results 1 to 15 of 15
Thread: Pic 12f629
    Jan 2008
    Unhappy Pic 12f629
    Hi I am very new to the 8pin pics
    I need some help using a 12f629 and all I want is for it to sense
    a hi or low on GP0 pin 7 and output on GP4 pin 3
    I am using an ICD2 programmer
    Configuration bits are:
    internal RC no clock
    Watchdog timer on
    power up timer off
    mclr enable external
    brown out detect on
    I have a 8k resistor connected from vdd to pin 4 MCLR
    I do not seem to get the pic to read an input condition
    my code is as follows
    DEFINE OSCCAL_1K 1
    RELAY VAR GPIO.4
    Pswitch VAR GPIO.0
    INITIALISE:
    CLEAR
    TRISIO = %00000001 '0 in rest output
    INTCON = %00000000
    PIR1 = %00000000
    PIE1 = %00000000
    WPU = %00000000
    CMCON = %11111111 'disable comparators
    PAUSE 10
    MAIN:
    While(pswitch = 1)
    relay = 0
    wend
    relay = 1
    GOTO MAIN
    I would be grateful if anyone could help
    Quote Originally Posted by runrite View Post
    Program looks ok, even used CMCON. Have you tried the old blinky LED program yet?
    Put an LED an GP4 and make it blink. When that works, put the switch on GP0, and turn the LED on and off with that switch under program control.
    After that, it should be easy to change it over to do what you want.
    Jan 2008
    Hi There thanks
    I have done just that on the input I have
    100k to ground permanently on GP0
    the switch is wired in this order +5V 10K switch then GP0
    still no luck
    It just does nt want to check the input condition I have a relay conected via a transistor to the output
    This is quite a puzzling problem
    Hi There thanks
    still no luck
    Your answer is just a little bit cryptic...
    Have you gotten the blinky LED thing to work?
    You have a relay connected to the output?
    Does it have a 'flyback diode' connected across the coil?
    Is the same power supply driving the PIC that's driving the relay coil?
    Jan 2008
    Hi there
    Yes 12V to relay and 5V to pic
    flyback diode
    If I change the code I can get the relay to go on and off
    I have used the 16f876's never had a problem like this
    am i not doing something wrong with the configuration in MP Lab
    I am using microcode studio with PBP
    flyback diode
    Maybe try turning off the WDT?
    Try different code, just for grins...
    if pswitch = 1 then relay = 0
    if pswitch = 0 then relay = 1
    I'm a sucker for simplicity.
    Try this;
    GPIO.4 ----/\/\/\---|<|----+5V.
                        LED
                 10K
    GPIO.0 --|--/\/\/\---+5V
             |--switch---GND.
    When you press the switch it grounds GPIO.0.
    @ device  pic12F629, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
        DEFINE OSCCAL_1K 1
        RELAY VAR GPIO.4   ' relay output
        Pswitch VAR GPIO.0 ' switch input
        TRISIO = %00000001 ' GPIO.0 input, rest outputs
        WPU = 0            ' input pull-ups disabled
        CMCON = 7          ' disable comparators
        PAUSE 10           ' POR delay
    MAIN:
        RELAY = ! Pswitch ' Relay pin = the opposite of Psiwtch pin
        GOTO MAIN
    Does this work?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    still no luck
    Not sure if it's 10k or 100k. 100k would be too high.
    But, either way ...
    Turn off the Pull-up's, by commenting the WPU statement.
    It's not letting the voltage go far enough towards Vss.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. program a pic 12f629
    By cancan in forum General
    Last Post: - 28th April 2008, 16:15
  4. Serial Pic to Pic using HSER
  5. Problem Pic 12f629
    By diegover in forum mel PIC BASIC Pro
    Last Post: - 19th July 2004, 12:51
