ASCII Viewer Needed
Results 1 to 8 of 8
    Feb 2005
    Kolkata-India
    Default My requirement is different
    Thanks Krohtec and Luciano for your reply. I could not make my point clear.
    1. I have the complete ASCII/HEX/OCT reference
    2. I have the complete EPSON ESCP Manual
    I have grabbed some field data and saved them to a log file using my PIC18F4550s SPP feature. Now I need to parse the data or in other words understand what the control software is sending to the printer.
    No opening the data in a HEX editor does the job and I can actually find out all the non-printable characters and so on. But it is a real pain as I have to manually check every byte.
    So I was looking for some prog which would let me view the underlying ASCII code of non-printable characters easily.
    My VB.net skill sucks!!! Still I am going to try write a log viewer. Actually this has been my requirement cause sometimes I would serially output some debug variable value and would not like its ASCII representation cause that kills more MCU cycles. For example say my ADC var is 215 then serial tx would be "2", "1", "5" which is at least three times the time taken to tx a single byte. Plus the overhead converting the binary value into ASCII representable value by the DEC funtion.
    So the bottomline is I need a text/binary file viewer that easily lets me peek at the ASCII value of each character.
    Sougata
    Apr 2006
    New Hampshire USA
    Smile Universal Viewer
    Hi sougata,
    This one says they have a free "lite" version:
    "Universal Viewer (ATViewer) is an advanced file viewer with wide range of formats supported."
    http://www.uvviewsoft.com/
    -Adam-
    Bombay, India
    Sougata
    Have you tried the editplus editor? It is freeware and has a hex viewer built into it. I think it is at http://www.editplus.com Moreover, it makes a very good programmers editor too.
    Jerson
    Feb 2005
    Kolkata-India
    Default Checking them out
    Thanks Adam and Jerson I will check both of your suggestion right away and report.
    Sougata
  1. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  2. IDE FineLine Viewer
    By Normnet in forum PBP Extensions
    Last Post: - 23rd August 2008, 04:15
  3. SerIn2 ASCII Conversion
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 4th March 2008, 22:41
  4. ascii conversion help needed
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2007, 07:33
  5. Conversion of 10-bit word into ASCII
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 16th January 2005, 15:26
