Good day
I am using the SN75176 to communicate (RS485) between two PICs.
For testing my cable is about 1m long running @ 4Mhz using PIC16F877.
I have a TX Pic and a RX Pic, on the RX side I send the data received to the PC for debuggin purposes.
I only transmit 1 character, and receive it on the RX side and send it to the PC.
<hr>
Here is the code for the TX side:
<code>
'======== RS485TX.BAS =====================
Include "Modedefs.bas"
DEFINE OSC 4 ' Set the Xtal frequency
P0 VAR PORTB.6
P1 VAR PORTB.7
CCP1CON = 0
ADCON1 = 7
OUTPUT P0
HIGH P0
SEROUT P1,N2400,["R"]
GOTO MAIN
</code>
<hr>
Here is the code for the RX side:
<code>
'======== RS485RX.BAS =====================
P0 VAR PORTB.6
P1 VAR PORTB.7
DEBUGPIN VAR PORTB.5
DATARECEIVED VAR BYTE
CCP1CON = 0
ADCON1 = 7
OUTPUT P0
LOW P0
SERIN P1,N2400,DATARECEIVED
SEROUT DEBUGPIN,N2400,["Received:", DATARECEIVED, 13, 10]
GOTO Main
</code>
<hr>
On the PC Side I get the following:
Received:R
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
Received:%
Received:J
Received:
Received:*
Received:T
Received:©
Received:R
Received:€
Received:I
Received:
<hr>
Any ideas
Thank you
Koossa
