RS485 Comms
Results 1 to 2 of 2
Thread: RS485 Comms
    Default RS485 Comms
    Good day
    I am using the SN75176 to communicate (RS485) between two PICs.
    For testing my cable is about 1m long running @ 4Mhz using PIC16F877.
    I have a TX Pic and a RX Pic, on the RX side I send the data received to the PC for debuggin purposes.
    I only transmit 1 character, and receive it on the RX side and send it to the PC.
    <hr>
    Here is the code for the TX side:
    <code>
    '======== RS485TX.BAS =====================
    Include "Modedefs.bas"
    DEFINE OSC 4 ' Set the Xtal frequency
    P0 VAR PORTB.6
    P1 VAR PORTB.7
    CCP1CON = 0
    ADCON1 = 7
    OUTPUT P0
    HIGH P0
    SEROUT P1,N2400,["R"]
    GOTO MAIN
    </code>
    <hr>
    Here is the code for the RX side:
    <code>
    '======== RS485RX.BAS =====================
    P0 VAR PORTB.6
    P1 VAR PORTB.7
    DEBUGPIN VAR PORTB.5
    DATARECEIVED VAR BYTE
    CCP1CON = 0
    ADCON1 = 7
    OUTPUT P0
    LOW P0
    SERIN P1,N2400,DATARECEIVED
    SEROUT DEBUGPIN,N2400,["Received:", DATARECEIVED, 13, 10]
    GOTO Main
    </code>
    <hr>
    On the PC Side I get the following:
    Received:R
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    Received:%
    Received:J
    Received:•
    Received:*
    Received:T
    Received:©
    Received:R
    Received:€
    Received:I
    Received:’
    <hr>
    Any ideas
    Thank you
    Koossa
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by koossa View Post
    Any ideas
    Thank you
    Koossa
    Notice how the output repeats itself?
    Try putting a slight pause in between each transmit at the transmitter end. You're transmitting characters without pauses. The receiver has to both receive and transmit characters, so it does that, and starts trying to receive another character after the transmitter has already sent half of it.
    At 2400 baud, throw a 'PAUSE 9' in between each character at the transmitter.
    2400 baud = .416ms/bit = 4.16ms/byte (start and stop bits included), receiver gets a character and transmits a character, same speed = 8.33ms. 9ms gives the receiver time to get done doing what it's gotta do before it's gotta do something else to get done.
  1. RS485 splitter
    Last Post: - 30th August 2009, 06:04
  2. RS485 Vs Wireless (TWS-434A)
    By koossa in forum Off Topic
    Last Post: - 11th April 2009, 12:40
  3. USB to RS485
    By The Master in forum USB
    Last Post: - 3rd January 2009, 03:49
  4. RS485 serial communication
    By mipie in forum Serial
    Last Post: - 10th February 2007, 13:15
  5. Pic to Pc Comms
    By Darrenmac in forum General
    Last Post: - 21st May 2005, 01:44
