who can let me knw where can i send out the temperature data out?
Results 1 to 6 of 6
    Quote Originally Posted by slimpeng View Post
    Hello i want to send out the temeperature data out at portc.6 so wat is the commnet i should to choose it and can u write down in my programming and at the portc.6 is my transmitter so the comment should is wat...and i want every 5s the data will display at LCD and send the data out again.....who can help me...pls........
    AND AGAIN, nobody, except for you, knows what sort of temperature sensor you are using, or for that matter, if your bluetooth transmitter is actually a serially driven part or what!
    MORE INFORMATION!
    Assuming that the temperature sensor that you are using actually puts out an analog voltage value which, in effect, directly translates to a binary equivalent of temperature, and the bluetooth module you are using is actually a serially driven module, and your are using a parallel mode LCD, and you have all of your hardware connected correctly (i.e. crystal, MCLR pullup, if used, power connections, ground connections, and so on and so on), then the program I wrote for you in the other thread in Post #2, should work.
    But AGAIN, I have no idea what sort of hardware we are dealing with here!
    Has any of this sunk in yet?
    Jan 2008
    and i using the 16F877A PIC and the sensor i using ptc type of sensor moduel gc-c103 and and i using voltage dividul rule and i will connet in to poartA.0 and ADC convert after that the LCD will show out the temperature value after get the value i using Bluetooth module to transmitter out the value to another receiver.......and i using code studio software to writing this programme and burn on the pic is use ICpro...
    Well, then, there you go.
    Except for the distinct possibility that the temperature curve won't be right, the program should work as I wrote it.
    Next question...Have you tried? What are your results?
    Jan 2008
    i try already the comment u write for me....all thing can working on simulator there...and i not yet try on my hardware because my pic give me burn ad so now need to waiting are new one caming...so i jst can try....thanks u so much to helpping me....
    A simulator?
    You have got to be kidding me!
    All this crap because you can't get it working on a simulator!
    Give me a break!
    Talk about leaving out KEY information.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
