Who can help me checking my Programming
Results 1 to 26 of 26
    Jan 2008
    HELLO skimask your post 2 source code...i can use in the my hardware part now i facing the problme is the temperature sensor no stable...i using the voltage divide rule to give the input on port A.0 rite...and when i start running the temperature will going to high to 255oC and why no stable same time i not use the sensor to burn on fire the value will automative increase or decrease and now i knw how to on the alarm on the portd ad...i try whole night and get the result ad....thanks....and who can let me kwn why the temperature sensor on this source code cant working stable and who can give me ideal or commnet....!
    thanks....!
    Quote Originally Posted by slimpeng View Post
    thanks....!
    Know what a 4-20mA current loop is?
    Jan 2008
    yup i know 4-20mA.....so wat should i do it now.....need to change the sensor or jst adding the resistor.......wat valuse of the resistor i need to change it....
    You send me the board your prototype is sitting on, and I'll GIVE you the resistor you need.
    Ever heard of a DS1820 or it's derivatives?
    Jan 2008
    now i using the voltage divider rule and the resister i will 18ohm and the test cricuit i will post at below and i got hear that D1820 that is digital temperature sensor...but i duno how to use it...i no use that before....and now how to make the sensor become stable.......
    on the pict the blue colour is my temperature sensor....
    and the resistor value is 18ohm
    and the red colour wire i connet to ADC on port A.0
    and the whole the circuit i also post at here ad...i hope u can help me....
    if really want to change the sensor D1820 the circuit how it look like and where can get it and the programe need to write again or not need...!
    Hi slimpeng,
    Here! Already written, and links to where to get it. You will be here 2 years from now trying to accomplish your goal with that thermistor. Oh, and please do try to use Google, it really does work to bring you good things, like data sheets, vendors, etc. . .
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2815/t/al
    @MyConfig = _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF
    @MyConfig = MyConfig & _BODEN_OFF
    @ __config  MyConfig
    ' One-wire temperature for LAB-X1 and DS1820
    Define PIC16F877A
    @ errorlevel -230
    temperature  Var	Word			' Temperature storage
    count_remain Var    Byte	 	    ' Count remaining
    count_per_c  Var	Byte			' Count per degree C
    DQ	Var	PORTC.0			' One-wire data pin
    define OSC 20
    TrisA = %00000000
    TrisB = %11111111
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 2000	 'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50	     'Define delay time between data sent.
      CMCON  = 7
    	ADCON1 = 7			' Set PORTA and PORTE to digital
    	Low PORTE.2			' LCD R/W line low (W)
    LCDOUT 254,1,"initializing"
    mainloop: OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    waitloop: OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	If count_remain = 0 Then waitloop
    	OWOut DQ, 1, [$CC, $BE]		' Read the temperature
            OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    	' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    	Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
    	' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature */ 461) + 3200
    	Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F"
            Pause 1000                      ' Display about once a second
    	Goto mainloop			' Do it forever
    Datasheets?
    Google?
    Search the forum?
    I'm done and out...Too much time used up already...not enough legwork at the other end.
    The items referred to in Post #6 have run out.
    Jan 2008
    last question....why the temperature going to high....oC and my LCD cant display any oC when going to low oC the LCD can display bck the value....why...! is my progrme problme...or what happen who can let me knw below is my new programe....!!!!
    help to check it
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 1/23/2008 *
    '* Version : 1.0 *
    '* Notes : *
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 1
    ' Define ADCIN parameters '
    Define ADC_BITS 8 ' Set number of bits in result
    include"modedefs.bas"
    TRISB=%11111111
    pause 2
    LCDOUT 254,1,2,2,2,"WELCOME MY"
    LCDOUT 254,192,2,"MONITOR SYSTEM"
    pause 3
    LCDOUT 254,1,"MY STARTING"
    LCDOUT 254,192,2,2,2,2,2,"TEMPERATURE"
    B0 var byte ' Create TEMPERATURE to store result
    TRISC.6=0
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 =%00001010 ' Set PORTA analog
    Low PORTB.2 ' LCD R/W line low (W)
    Pause 1000
    loop:
    ADCIN 0,B0 ' Read channel 0 to adval
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value: ",DEC B0,"'C" ' Display the decimal value
    serout portc.6,n2400,[#b0]
    Pause 5000 ' Wait .5 second
    Goto loop ' Do it forever
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 17:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 14:36
