Who can help me checking my Programming
Results 1 to 26 of 26
    Quote Originally Posted by LinkMTech View Post
    I'm probably not the only one that hesitates asking a simple question for fear of getting a verbal lashing for reading and not understanding the information provided either in responses or the data sheets.
    Big difference between trying to 'read and understand the information'...and not having done squat to help yourself.
    Or having to have our project pre-approved by you before making a suggestion.
    Hey, I'm a choad like the rest of the shmucks around here, I know, they know it...Dig it...
    Your definition of patience is warped and unfortunately it seems to me that some of the other "experts" are getting tired too.
    I just might be able to draw a bit of a conclusion there...Ya think?
    If you feel your forehead forming a scowl
    Scowl? No... Roll of the eyes? Maybe... Laughter? Ok, I'll buy that one.
    do us a favor... don't respond.
    Too late...
    Because a lot of us are not at the same experience level you are and don't need the added aggrevation that comes with learning something new.
    Guess how I got that much experience?
    There wasn't much for forums back then...
    My two cents.
    Taken...
    Jan 2008
    HELLO...skimask.....i want to ask u some thing....your post 2 the programme i can use it...if i want the temperature reach to 60oC and on alarm so wat the comment should i wirte it...the comment is like if portc.6=60oC then portd =1 rite or not.............if cant can u write down and example for me see it....
    thanks u so much
    Quote Originally Posted by slimpeng View Post
    thanks u so much
    Sure...I'll be right over there to write the code for you.
    I'll even bring my whole setup...PC, keyboard, mouse, all my books...heck, I'll even bring over working hardware and donate it ALL to you...
    Just for you...
    I'll even bring the beer and some refreshments and a couple of DVDs, a big screen TV and a surround sound system to help pass the time...
    Jan 2008
    hello....skimask........no need say like that ok......if i can done well at picbaisc pro i no need come here to ask u ad....so this is my last question ad...so help me last time ok pls....
    at post 12.....i really duno i try many time ad still cant working....
    i want the temperature reach to high oC around 60 to 100oC will go to on the alarm at port D after lcd will show out temperature is too Hot.....that all....
    hope skimask can help me....pls.............i really duno......pls............
    I'll be right over...
    Super swell good and dandy fine ok then?
    Jan 2008
    hello skimask....sorry to disturb u again....my last part progrme on the alarm u help me write over ad mah..........i very urgent need that part if i not i will die.....it and help me......pls...help ppl god also will protect u and give u every day good luck for u.......thannks u very much......!!!!!
    A cry for help?
    What?
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 17:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 14:36
