PIC HANGS with SERIN and Timeout?
Results 1 to 21 of 21
    I do not use spaces in the SERIN2. Try:
    SERIN2 P1,N2400,10,Loop,[wait("T"),DATARECEIVED]
    And maybe use 16780 instead of N2400? And DEC before DATARECEIVED.
    Maybe
    Maybe
    I haven't had a problem with spaces in PBP2.50, had problems back in 2.42 I think it was.
    I've got a program that has about 50-60 different SERIN2 lines and they all look like:
    SERIN2 serialinpin , 84 , 5000 , baddata , [ WAIT ( ">" ) , STR string\255 ]
    Lots of spaces, etc.etc.etc...like I said, the older PBP, broke, newer, good.
    COOL ,Now I need to upgrade. I am still at 2.47.
    I tell ya, in my little world, it's those LONG's that make all the difference.
    Thank you for your replies!!
    I Think this is it!!
    http://www.picbasic.co.uk/forum/show...highlight=idle
    Quote Originally Posted by koossa View Post
    That be the one...I'm fairly sure anyways...
    I just came out of a four hour meeting with one of those as Dilbert says Pointy Haired Bosses. So my brain is still a bit dead...
    What are you talking about? "LONGs" ?
    LONGs = double words, 32 bits (31 bits + sign) math, no more DIV32 (not included in PBPL because PBPL will do 32 bits)...
    Check the melabs website for the upgrade info.
    That is something to get excited about. I really need to keep up with things.
    Thanks again!
    Sep 2003
    Vermont
    This may be a moot point, but, I recently had the hang situation with a GPS unit interface. The unit's serial output would go to ground when the unit was put into sleep. I did a little loop that would sense if the line went high at all over a hundred mS period. If not,I would skip the Serin line. It works quite well without any hardware changes.
    Ron
    Thank you Ron, I will keep that in mind!
    I'm a real beginner with PICS and don't understand the posts about idling that good.
    If I connect he Serin Pin to ground it don't hang anymore, or if I rather use the "True" and not "inverted" state.
    Is any one of these a reliable solution?
    Sorry to jump in late. Just tie a 4.7 K between the serin pin and ground; should solve the problem.
    Anand
    Thank you Anand, I will do!!
    Oh...hey...good point...no kidding.
    Jeez, sometimes the simplest fixes are the best.
    And if tying it to ground doesn't work (which it should), tie it high, or maybe use a 10K instead of a 4.7K, or maybe a 1K. Might take a bit of experimentation. But I don't see why 4.7K shouldn't work just fine.
  1. Serin timeout not working properly!
    Last Post: - 1st January 2010, 21:56
  2. PIC Hangs when using Serin TimeOut
    By Squibcakes in forum Serial
    Last Post: - 20th July 2006, 02:59
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 08:33
