PIC HANGS with SERIN and Timeout?
Results 1 to 21 of 21
    Default PIC HANGS with SERIN and Timeout?
    I'm struggling for hours now.
    I use the following code and added an LED Blink for debug purposes,
    but only gets one blink and then it hangs (on the serin2).
    I have also tried serin.
    Using Pic16F877 and have 2 PIR Sensors,
    one on SENSORPIN1 and one on SENSORPIN2.
    Any ideas?
    <code>
    &nbsp;&nbsp;&nbsp;Include "Modedefs.bas"
    &nbsp;&nbsp;&nbsp;DEFINE&nbsp;&nbsp;&nbsp;OSC 4 ' Set the Xtal frequency
    &nbsp;&nbsp;&nbsp;N2400&nbsp;&nbsp;&nbsp;CON 16780
    &nbsp;&nbsp;&nbsp;P0&nbsp;&nbsp;&nbsp;VAR PORTB.6
    &nbsp;&nbsp;&nbsp;P1&nbsp;&nbsp;&nbsp;VAR PORTB.7
    &nbsp;&nbsp;&nbsp;SENSORNUMBER&nbsp;&nbsp;&nbsp;CO N 0
    &nbsp;&nbsp;&nbsp;SENSORPIN1&nbsp;&nbsp;&nbsp;V AR PORTB.4
    &nbsp;&nbsp;&nbsp;SENSORPIN2&nbsp;&nbsp;&nbsp;V AR PORTB.5
    &nbsp;&nbsp;&nbsp;LEDPIN&nbsp;&nbsp;&nbsp;VAR PORTD.1
    &nbsp;&nbsp;&nbsp;SENSORSTATUS&nbsp;&nbsp;&nbsp;VA R BYTE
    &nbsp;&nbsp;&nbsp;DATARECEIVED&nbsp;&nbsp;&nbsp;va r byte
    &nbsp;&nbsp;&nbsp;CCP1CON = 0
    &nbsp;&nbsp;&nbsp;ADCON1 = 7
    &nbsp;&nbsp;&nbsp;OUTPUT LEDPIN
    &nbsp;&nbsp;&nbsp;input SENSORPIN1
    &nbsp;&nbsp;&nbsp;input SENSORPIN2
    Loop:
    &nbsp;&nbsp;&nbsp;IF (SENSORPIN1 = 1) OR (SENSORPIN2 = 1) THEN
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SENSORSTATU S = "1"
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;HIGH LEDPIN
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAUSE 1000
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LOW LEDPIN
    &nbsp;&nbsp;&nbsp;ENDIF
    &nbsp;&nbsp;&nbsp;OUTPUT P0
    &nbsp;&nbsp;&nbsp;INPUT P1
    &nbsp;&nbsp;&nbsp;LOW P0
    &nbsp;&nbsp;&nbsp;' ============ LED BLINK FOR DEBUG PURPOSES =================
    &nbsp;&nbsp;&nbsp;' ================================================== =========
    &nbsp;&nbsp;&nbsp;SERIN2 P1, N2400, 10, Loop,[wait("T"),DATARECEIVED]
    &nbsp;&nbsp;&nbsp;if (DATARECEIVED = SENSORNUMBER) then
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;OUTPUT P1
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SEROUT2 P1, N2400, ["R",SENSORSTATUS]
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SENSORSTATU S = "0"
    &nbsp;&nbsp;&nbsp;endif
    &nbsp;&nbsp;&nbsp;Goto Loop
    </code>
    Thank you!!
    koossa
    Quote Originally Posted by koossa View Post
    Any ideas?
    koossa
    I think this is going to tie back into that IDLE state thing, not sure off the top of my head.
    Do a search on the IDLE. Seems to me, if the pin is IDLING in the wrong state, SERIN will hangout waiting for something that ain't comin...
    In the meanwhile, try using a timeout in the SERIN command and see what happens.
    Skimask, thank you very much for your feedback.
    I have taken a look at the idling thing, but don't understand it.
    I have also tried both SERIN and SERIN2 with timeout (10 milliseconds)
    Koossa
    Koossa
    Well, I've never had the idling problem myself, so I can't really comment.
    About all I can suggest is to read the threads again (there's one by Melanie that's especially long and useful) and you're answer will be in there somewhere.
    If I would have to guess, I would say that your input pin is just sitting there at a low logic level. If it is, pull it high and see if the timeout works.
    If it's sitting high, pull it low and see if the timeout works.
    I do not use spaces in the SERIN2. Try:
    SERIN2 P1,N2400,10,Loop,[wait("T"),DATARECEIVED]
    And maybe use 16780 instead of N2400? And DEC before DATARECEIVED.
    Maybe
    Maybe
    I haven't had a problem with spaces in PBP2.50, had problems back in 2.42 I think it was.
    I've got a program that has about 50-60 different SERIN2 lines and they all look like:
    SERIN2 serialinpin , 84 , 5000 , baddata , [ WAIT ( ">" ) , STR string\255 ]
    Lots of spaces, etc.etc.etc...like I said, the older PBP, broke, newer, good.
    COOL ,Now I need to upgrade. I am still at 2.47.
    I tell ya, in my little world, it's those LONG's that make all the difference.
    Thank you for your replies!!
    I Think this is it!!
    http://www.picbasic.co.uk/forum/show...highlight=idle
    I just came out of a four hour meeting with one of those as Dilbert says Pointy Haired Bosses. So my brain is still a bit dead...
    What are you talking about? "LONGs" ?
    LONGs = double words, 32 bits (31 bits + sign) math, no more DIV32 (not included in PBPL because PBPL will do 32 bits)...
    Check the melabs website for the upgrade info.
    That be the one...I'm fairly sure anyways...
    That is something to get excited about. I really need to keep up with things.
    Thanks again!
    Sep 2003
    Vermont
    This may be a moot point, but, I recently had the hang situation with a GPS unit interface. The unit's serial output would go to ground when the unit was put into sleep. I did a little loop that would sense if the line went high at all over a hundred mS period. If not,I would skip the Serin line. It works quite well without any hardware changes.
    Ron
    Thank you Ron, I will keep that in mind!
    I'm a real beginner with PICS and don't understand the posts about idling that good.
    If I connect he Serin Pin to ground it don't hang anymore, or if I rather use the "True" and not "inverted" state.
    Is any one of these a reliable solution?
    Sorry to jump in late. Just tie a 4.7 K between the serin pin and ground; should solve the problem.
    Anand
    Thank you Anand, I will do!!
    Oh...hey...good point...no kidding.
    Jeez, sometimes the simplest fixes are the best.
    And if tying it to ground doesn't work (which it should), tie it high, or maybe use a 10K instead of a 4.7K, or maybe a 1K. Might take a bit of experimentation. But I don't see why 4.7K shouldn't work just fine.
    I would try to find or fix the problem VS using the external resistor. Especially if you're using the same pin for sending & receiving serial data.
    If the other device is holding its pin at logic 1, and you do make it through to your SEROUT2 routine in the lower section, you have a potential short between two pins.
    The idle state just means the serial input or output pins are held at the idle logic level during periods when no serial data is being transmitted or received.
    For inverted, the TX output should idle at logic 0. And the RX input should be held at logic 0 by the sending device for the SERIN2 timeout/label options to work.
    PBP times the idle logic on the RX pin for the duration of the timeout period. If it sees noise, or a steady non-idle logic signal on the RX pin, the timeout period gets reset, and it never exits to the label.
    If you're using two PIC's talking together on a serial network type connection with the same pins on each side being used for TX & RX, then you might want to use one of the open baud modes.
    If you use SEROUT2/SERIN2 then use mode # 49548, and use the pull-down resistor on the serial network TX/RX pins.
    For inverted, open baud mode, the resistor holds the pin that's transmitting & receiving on the serial network at the idle logic level. Each PIC will TX a logic 1 only. Logic 0 for data bits and the idle state is handled by the pull-down resistor.
    For true mode you would use a pull-up resistor on the serial network pins, and each PIC would output only logic 0 when transmitting serial data. Logic 1 gets handled by the pull-up resistor. Open baud modes are really handy for single pin serial networks.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I would try to find or fix the problem..........
    Should sticky this in the FAQ's somewhere...
    Like I said, haven't had the problem myself, but I'm sure that day is coming...
  1. Serin timeout not working properly!
    Last Post: - 1st January 2010, 20:56
  2. PIC Hangs when using Serin TimeOut
    By Squibcakes in forum Serial
    Last Post: - 20th July 2006, 01:59
  3. 16F628A Serin timeout and Timer1
    Last Post: - 26th March 2006, 23:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 07:33
