PIC HANGS with SERIN and Timeout?
Results 1 to 21 of 21
    Default PIC HANGS with SERIN and Timeout?
    I'm struggling for hours now.
    I use the following code and added an LED Blink for debug purposes,
    but only gets one blink and then it hangs (on the serin2).
    I have also tried serin.
    Using Pic16F877 and have 2 PIR Sensors,
    one on SENSORPIN1 and one on SENSORPIN2.
    Any ideas?
    <code>
    &nbsp;&nbsp;&nbsp;Include "Modedefs.bas"
    &nbsp;&nbsp;&nbsp;DEFINE&nbsp;&nbsp;&nbsp;OSC 4 ' Set the Xtal frequency
    &nbsp;&nbsp;&nbsp;N2400&nbsp;&nbsp;&nbsp;CON 16780
    &nbsp;&nbsp;&nbsp;P0&nbsp;&nbsp;&nbsp;VAR PORTB.6
    &nbsp;&nbsp;&nbsp;P1&nbsp;&nbsp;&nbsp;VAR PORTB.7
    &nbsp;&nbsp;&nbsp;SENSORNUMBER&nbsp;&nbsp;&nbsp;CO N 0
    &nbsp;&nbsp;&nbsp;SENSORPIN1&nbsp;&nbsp;&nbsp;V AR PORTB.4
    &nbsp;&nbsp;&nbsp;SENSORPIN2&nbsp;&nbsp;&nbsp;V AR PORTB.5
    &nbsp;&nbsp;&nbsp;LEDPIN&nbsp;&nbsp;&nbsp;VAR PORTD.1
    &nbsp;&nbsp;&nbsp;SENSORSTATUS&nbsp;&nbsp;&nbsp;VA R BYTE
    &nbsp;&nbsp;&nbsp;DATARECEIVED&nbsp;&nbsp;&nbsp;va r byte
    &nbsp;&nbsp;&nbsp;CCP1CON = 0
    &nbsp;&nbsp;&nbsp;ADCON1 = 7
    &nbsp;&nbsp;&nbsp;OUTPUT LEDPIN
    &nbsp;&nbsp;&nbsp;input SENSORPIN1
    &nbsp;&nbsp;&nbsp;input SENSORPIN2
    Loop:
    &nbsp;&nbsp;&nbsp;IF (SENSORPIN1 = 1) OR (SENSORPIN2 = 1) THEN
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SENSORSTATU S = "1"
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;HIGH LEDPIN
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAUSE 1000
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LOW LEDPIN
    &nbsp;&nbsp;&nbsp;ENDIF
    &nbsp;&nbsp;&nbsp;OUTPUT P0
    &nbsp;&nbsp;&nbsp;INPUT P1
    &nbsp;&nbsp;&nbsp;LOW P0
    &nbsp;&nbsp;&nbsp;' ============ LED BLINK FOR DEBUG PURPOSES =================
    &nbsp;&nbsp;&nbsp;' ================================================== =========
    &nbsp;&nbsp;&nbsp;SERIN2 P1, N2400, 10, Loop,[wait("T"),DATARECEIVED]
    &nbsp;&nbsp;&nbsp;if (DATARECEIVED = SENSORNUMBER) then
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;OUTPUT P1
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SEROUT2 P1, N2400, ["R",SENSORSTATUS]
    &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SENSORSTATU S = "0"
    &nbsp;&nbsp;&nbsp;endif
    &nbsp;&nbsp;&nbsp;Goto Loop
    </code>
    Thank you!!
    koossa
    Quote Originally Posted by koossa View Post
    Any ideas?
    koossa
    I think this is going to tie back into that IDLE state thing, not sure off the top of my head.
    Do a search on the IDLE. Seems to me, if the pin is IDLING in the wrong state, SERIN will hangout waiting for something that ain't comin...
    In the meanwhile, try using a timeout in the SERIN command and see what happens.
    Skimask, thank you very much for your feedback.
    I have taken a look at the idling thing, but don't understand it.
    I have also tried both SERIN and SERIN2 with timeout (10 milliseconds)
    Koossa
    Koossa
    Well, I've never had the idling problem myself, so I can't really comment.
    About all I can suggest is to read the threads again (there's one by Melanie that's especially long and useful) and you're answer will be in there somewhere.
    If I would have to guess, I would say that your input pin is just sitting there at a low logic level. If it is, pull it high and see if the timeout works.
    If it's sitting high, pull it low and see if the timeout works.
    I do not use spaces in the SERIN2. Try:
    SERIN2 P1,N2400,10,Loop,[wait("T"),DATARECEIVED]
    And maybe use 16780 instead of N2400? And DEC before DATARECEIVED.
    Maybe
    Maybe
    I haven't had a problem with spaces in PBP2.50, had problems back in 2.42 I think it was.
    I've got a program that has about 50-60 different SERIN2 lines and they all look like:
    SERIN2 serialinpin , 84 , 5000 , baddata , [ WAIT ( ">" ) , STR string\255 ]
    Lots of spaces, etc.etc.etc...like I said, the older PBP, broke, newer, good.
    COOL ,Now I need to upgrade. I am still at 2.47.
    Sep 2003
    Vermont
    This may be a moot point, but, I recently had the hang situation with a GPS unit interface. The unit's serial output would go to ground when the unit was put into sleep. I did a little loop that would sense if the line went high at all over a hundred mS period. If not,I would skip the Serin line. It works quite well without any hardware changes.
    Ron
  1. Serin timeout not working properly!
    Last Post: - 1st January 2010, 20:56
  2. PIC Hangs when using Serin TimeOut
    By Squibcakes in forum Serial
    Last Post: - 20th July 2006, 01:59
  3. 16F628A Serin timeout and Timer1
    Last Post: - 26th March 2006, 23:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 07:33
