detect1 to 0 change on RA0
Results 1 to 4 of 4
    Jan 2008
    lincoln uk
    Unhappy detect1 to 0 change on RA0
    Why does this fall through?
    loop:
    IF porta.0 = 1 then loop
    next lot of basic code follows here
    RA0 is tied up via 10K and a press button grounds it, to get out of the loop, but...it fall thro anyway
    Rgds
    Mike URGENT for my sanity
    Quote Originally Posted by med2007 View Post
    loop:
    Rgds
    Think analog...
    Think datasheets...
    Think about telling which PIC you're using...
    Just a few things to think about...
    And also your configurations, DEFINES, schematic, etc.
    Why don't you post your code? If you seek help from experts, then do not worry about stealing you code... They sure know and do better!
    With no infos, only guesses can be made. And I am not good at. If I was I would have won the Lotto or Casino or something anyway...
    Jan 2008
    lincoln uk
    Smile detect 0 to 1 on RA0
    Thanks guys, the answer is to configure porta for digital I/O, which I hadn't done.
    CMCON = %00000111 using 16F628
    Rgds
  1. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 19:53
  2. encoder port change
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 18th September 2009, 19:41
  3. pic18f4520 baud rate change to 115200
    By caltex88 in forum mel PIC BASIC Pro
    Last Post: - 30th September 2007, 08:41
  4. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 20:55
  5. help!! With Keypad change
    By clare1 in forum mel PIC BASIC Pro
    Last Post: - 12th December 2006, 21:13
