Debugin
Results 1 to 7 of 7
Thread: Debugin
    Jan 2008
    Thumbs down debuggin
    I am using the adcin command for my anolog inputs, and the debuggin command should
    make the pin an input. I don't have cmcono or ansel in my program anywhere.
    Quote Originally Posted by tbh9365 View Post
    Oh, DEBUG will make the pin an input all right, but only if the pin is selected as an input.
    Read the datasheet for the 16F648, page 31 of DS41202F, the note highlighted on the right side of the page.
    Jan 2008
    Default debuggin
    I don't understand how to set these registers, I have the RA1 pin set as Vref,
    and RA0,RA2,RA3,RA5 as anolog inputs. I am trying to use RA4(an3) as the debugin
    pin. My registers are set as follows:
    cmcon0 = %11110000
    ansel = %10101
    adcon0 = %01001000
    How far off am I? And what do I need to change?
    I don't understand how to set these registers, I have the RA1 pin set as Vref, and RA0,RA2,RA3,RA5 as anolog inputs. I am trying to use RA4(an3) as the debugin pin. My registers are set as follows:
    cmcon0 = %11110000
    ansel = %10101
    adcon0 = %01001000
    And more information that would've been a lot more helpful much earlier in the process...
    You're trying to use RA4/AN3 as a digital input, which means you aren't using it as OSC2 or a Fosc/4 clockout, which means you are most likely using the internal oscillator, which means that it may need to be tweaked a bit to get the baud rate correct (see OSCTUNE)...and do a search on that term.
    Am I about right here?
    Jan 2008
    Default debugin
    You are correct, I am using the internal Osc. on the Pic 16F684, and a Ceramic Resonator on
    the Pic 16f84A, of 4mhz, And the internal Osc should be 4mhz also on the 684, I will double
    check this. I will also read up on the tuneing and give it a try. Thanks again
  1. DEBUGIN not working on 12F629
    By fredpret in forum Serial
    Last Post: - 22nd September 2007, 11:39
  2. Serin / Serin2 / Debugin Differences
    Last Post: - 19th January 2006, 06:32
  3. DebugIn problem
    By Mutiaz in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2006, 15:51
  4. Debugin Causesing Restart
    By IceCube in forum mel PIC BASIC Pro
    Last Post: - 30th September 2004, 01:20
  5. Debugin problem
    By moby in forum mel PIC BASIC Pro
    Last Post: - 11th September 2004, 15:12
