I'm new so I tried to search for the answer on the forum but couldn't find it.
I am trying to send info from one pic (pic16F84A) using the debugin command.
I debug the info from the pic16f84a and it is being sent. I then try to get the
other pic, (pic16f684) to place the info into a variable and then debug it to the serial communicator.
I get nothing. If I remove the debugin command then the pic 16F684 debugs all the
other info correctly. I have defined the debugin_bit as another pin and I have tried
leaving it as the default bit. Any suggestions would be appreciated.
