16F872 and LCD
Results 1 to 40 of 49
Thread: 16F872 and LCD
Threaded View
  1. #37
    Jan 2008
    Quote Originally Posted by Pic_User View Post
    Hi Fredrick,
    The LM317 package would be rated at 1.5A with a very good heat-sink and the correct input voltage, to avoid, dropping too much voltage and heating itself.
    (input – output differential V)
    http://cache.national.com/ds/LM/LM117.pdf
    With no heat sink, 15 V input 5 V output, the 317 could overheat with just over 200 mA at 25 C.
    Regulator Heatsink Calculator
    http://www.ef-uk.net/data/heatsinking.htm
    How much current does the OLED LCD display draw?
    Is the voltage regulator getting hot (to your touch)?
    Can you “oscilloscope” the +5V supply? Watch for the voltage to dropout.
    -Adam-
    Ok thanx
    The VR is not getting hot.
    Edit: Heat sink is added just in case...
    http://www.elfa.se/elfa-bin/dyndok.p...dok=245171.htm
