16F872 and LCD
Results 1 to 40 of 49
Thread: 16F872 and LCD
    Try this for Waitloop ...
    ' Check for still busy converting ( ~ 4500 fois ... )
    waitloop:
    		INPUT DQ
    		If NOT DQ Then waitloop
    AND ....
    DEFINE LCD_DATAUS 600
    Should be ...
    Jan 2008
    Angry
    Doesn´t work.
    Lightbulb
    Aha ...
    ' One-wire temperature for Picboard and DS1820
    'Ok le 29/08/2004 - 534 lignes
    Define	LCD_EBIT	1
    DQ				Var	PORTB.4		' One-wire data pin
    Ok				Var PORTB.5		' Led Verte
    Waito			Var PORTB.6		' Led Orange
    Error			Var PORTB.7		' Led Rouge
    temperature 	Var	Word			' Temperature storage
    count_remain 	Var Byte			' Count remaining
    count_per_c 	Var	Byte			' Count per degree C
    offset			Var Word			' 100 * offset réel !!!
    offset = 293
    PAUSE 500
    LCDOUT $FE,1
    ' Start temperature conversion
    mainloop: OWOut DQ, 1, [$CC, $44 ]
    waitloop:
    		INPUT DQ
    ' Read the temperature
    	OWOut DQ, 1, [$CC, $BE ]
        OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)+ offset
    	Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"C"
    ' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature */ 461) + 3200
    	Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"F"
    ' Display about once a second
            Pause 1000
    	Goto mainloop			' Do it forever
    looks we have the same source !!! ... This one works perfectly aboard a 16F84 ...
    soo ... let's check the 872 config ... AND,AND,AND :
    Wich PbP version do you use ... and has your PBPpic14.lib being modified ???
    There was an interesting thread those days about 1Wire and > 8 Mhz Osc ...
    see here : http://www.picbasic.co.uk/forum/show...79&postcount=4
    Jan 2008
    I use PBP v2.45 and have not modified anything.
    The PIC runs on OSC 20
    Edit: Just tryed to put in a 4 Mhz crystal but i does´t work
    Quote Originally Posted by Fredrick View Post
    Apparently, the bug mentioned at the end of post #9 is only applicable to PBP2.50(a).
    But still, something wierd going on...
    Change your LCD_DATAUS from 600 to 255.
    LCD_DATAUS is a byte value (up until PBP2.50 as far as I know), so 600 is actually 88 (600 - 256 - 256 ) as far as PBP knows.
    Past that...
    Check the pullup on MCLR?
    Watchdog timer off?
    Jan 2008
    I dont know what i have done but now the display shows "333333333333333" on both lines and some times the temerature shows on diffrent positions in the display whit "3" all over the display.
    The display is an HD44780 OLED, can the display be broken?
    The PBP Hello World sampel works..
    I'm sure the 'Hello World' sample works just fine, but when you start messing around with some of the special LCD commands and stuff, the LCD timing starts to matter.
    Did you change the LCD_DATAUS yet?
    Place this in the first section of your code;
    @ device pic16F872, hs_osc, wdt_off, pwrt_on, lvp_off, protect_off
    Change DEFINE LCD_DATAUS 600 to DEFINE LCD_DATAUS 50.
    Does it work now?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2008
    No i does not work...
    Sounds like it's time to get the 2.50a update...
    Jan 2008
    Why? 2.45 should work...
    And update the PBP is not an garanti for that i will work..
    The update is only $25, get a new book, all the fixes, support for 32 bit variables, etc.
