16F872 and LCD
Results 1 to 40 of 49
Thread: 16F872 and LCD
    Jan 2008
    But the manual doese´t shows the default connections for 16F872, what are the defaults for my PIC?
    Can i want use RB1 to RB6 insted och the default or does i have to use pin´s from outher ports?
    btw why does the PIC have diffrent ports like PORTA, PORTB, PORTC..
    And yes i´m new to PIC programing and i have just get my LED to blink when i push a button
    Don't worry, the default one are the same for all PIC model.
    Not sure what you mean
    Quote Originally Posted by Fredrick View Post
    Actually the manual does show the default connections.......for all PICs!
    If you don't redefine the pins, they'll default to what the manual says, so long as those pins actually exist.
    In a roundabout way, you can use any pin you want (using DT's ANYPIN routines) for the LCDIN/LCDOUT commands, but I'm guessing that's probably a bit above your skill at the moment. Give it time and anything is possible.
    I suppose they could name them anything they want, just call them 1 thru 30, or A-Z or whatever.
    But, since the PIC16F872 is primarily an 8bit device, it therefore makes a bit more sense to divide up the pins into 8 bit chunks as much as possible to keep the firmware/instructions/etc a bit simpler.
    Quite frankly, you won't see a lot of 6 bit or 13 bit devices out there, or some other off the wall number. Pretty much everything is either 1,4,8, or 16 bits (yes, there are exceptions to the rule, just not a lot).
    Get on it! Make 2 LEDs blink with 3 buttons... Then make a servo move with the buttons, then make a .... see how it goes?
    Get out while you can! It's a never ending cycle man!!! You'll end up spending all of your money on the latest greatest thing out there!!! Blowing all of your sleep time programming PICs... Lose your money, house, sanity...it's like drugs! It's terrible!!!
    Ok, not really...but you get the point...(as for me, I'll never learn!)
    Jan 2008
    Hello.
    Now i have connected the LCD as PBP defaults and when i run the PIC with this code the display shown the temerature for 1sec and then it shows "fffffffffffffffffffffff" on both lines for a sec and then shows the temerature again and so on...
    Why?
    ' One-wire temperature for LAB-X1 and DS1820
    define OSC 20
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 600
    temperature Var	Word			' Temperature storage
    count_remain Var Byte			' Count remaining
    count_per_c Var	Byte			' Count per degree C
    DQ	Var	PORTB.2			' One-wire data pin
    	ADCON1 = 7			' Set PORTA and PORTE to digital
    mainloop: OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    waitloop: OWIn DQ, 4, [count_remain]	' Check for still busy converting
        If count_remain = 0 Then waitloop
    	OWOut DQ, 1, [$CC, $BE]		' Read the temperature
        OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    	' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    	Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
    	' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature */ 461) + 3200
    	Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F"
        Pause 1000                      ' Display about once a second
    	Goto mainloop			' Do it forever
    Try this for Waitloop ...
    ' Check for still busy converting ( ~ 4500 fois ... )
    waitloop:
    		INPUT DQ
    		If NOT DQ Then waitloop
    AND ....
    Should be ...
    Jan 2008
    Angry
    Doesn´t work.
    Lightbulb
    Aha ...
    ' One-wire temperature for Picboard and DS1820
    'Ok le 29/08/2004 - 534 lignes
    Define	LCD_EBIT	1
    DQ				Var	PORTB.4		' One-wire data pin
    Ok				Var PORTB.5		' Led Verte
    Waito			Var PORTB.6		' Led Orange
    Error			Var PORTB.7		' Led Rouge
    offset			Var Word			' 100 * offset réel !!!
    offset = 293
    PAUSE 500
    LCDOUT $FE,1
    mainloop: OWOut DQ, 1, [$CC, $44 ]
    waitloop:
    		INPUT DQ
    	OWOut DQ, 1, [$CC, $BE ]
    	temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)+ offset
    	Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"C"
    	Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " ",$DF,"F"
            Pause 1000
    looks we have the same source !!! ... This one works perfectly aboard a 16F84 ...
    soo ... let's check the 872 config ... AND,AND,AND :
    Wich PbP version do you use ... and has your PBPpic14.lib being modified ???
    There was an interesting thread those days about 1Wire and > 8 Mhz Osc ...
    see here : http://www.picbasic.co.uk/forum/show...79&postcount=4
    Jan 2008
    I use PBP v2.45 and have not modified anything.
    The PIC runs on OSC 20
    Edit: Just tryed to put in a 4 Mhz crystal but i does´t work
