How do i know the right pins i should connect my LCD display to? or can i select my own pins in my program?
The manual show the default connections. You can also select your own and add some DEFINEs at the top of your program.
Code:' ' LCD setup ' ========= DEFINE LCD_DREG PORTB ' LCD data port DEFINE LCD_DBIT 0 ' LCD data starting bit DEFINE LCD_RSREG PORTB ' LCD register select port DEFINE LCD_RSBIT 4 ' LCD register select bit DEFINE LCD_EREG PORTB ' LCD enable port DEFINE LCD_EBIT 5 ' LCD enable bit DEFINE LCD_BITS 4 ' LCD data bus size DEFINE LCD_LINES 2 ' Number lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us
But the manual doese´t shows the default connections for 16F872, what are the defaults for my PIC?
Can i want use RB1 to RB6 insted och the default or does i have to use pin´s from outher ports?
btw why does the PIC have diffrent ports like PORTA, PORTB, PORTC..
And yes i´m new to PIC programing and i have just get my LED to blink when i push a button![]()
Don't worry, the default one are the same for all PIC model.But the manual doese´t shows the default connections for 16F872, what are the defaults for my PIC?
Not sure what you meanCan i want use RB1 to RB6 insted och the default or does i have to use pin´s from outher ports?![]()
Actually the manual does show the default connections.......for all PICs!
If you don't redefine the pins, they'll default to what the manual says, so long as those pins actually exist.
In a roundabout way, you can use any pin you want (using DT's ANYPIN routines) for the LCDIN/LCDOUT commands, but I'm guessing that's probably a bit above your skill at the moment. Give it time and anything is possible.Can i want use RB1 to RB6 insted och the default or does i have to use pin´s from outher ports?
I suppose they could name them anything they want, just call them 1 thru 30, or A-Z or whatever.btw why does the PIC have diffrent ports like PORTA, PORTB, PORTC..
But, since the PIC16F872 is primarily an 8bit device, it therefore makes a bit more sense to divide up the pins into 8 bit chunks as much as possible to keep the firmware/instructions/etc a bit simpler.
Quite frankly, you won't see a lot of 6 bit or 13 bit devices out there, or some other off the wall number. Pretty much everything is either 1,4,8, or 16 bits (yes, there are exceptions to the rule, just not a lot).
Get on it! Make 2 LEDs blink with 3 buttons... Then make a servo move with the buttons, then make a .... see how it goes?And yes i´m new to PIC programing and i have just get my LED to blink when i push a button![]()
Get out while you can! It's a never ending cycle man!!! You'll end up spending all of your money on the latest greatest thing out there!!! Blowing all of your sleep time programming PICs... Lose your money, house, sanity...it's like drugs! It's terrible!!!
Ok, not really...but you get the point...(as for me, I'll never learn!)
Hello.
Now i have connected the LCD as PBP defaults and when i run the PIC with this code the display shown the temerature for 1sec and then it shows "fffffffffffffffffffffff" on both lines for a sec and then shows the temerature again and so on...
Why?
Code:' One-wire temperature for LAB-X1 and DS1820 define OSC 20 DEFINE LCD_COMMANDUS 2000 DEFINE LCD_DATAUS 600 temperature Var Word ' Temperature storage count_remain Var Byte ' Count remaining count_per_c Var Byte ' Count per degree C pause 1000 DQ Var PORTB.2 ' One-wire data pin ADCON1 = 7 ' Set PORTA and PORTE to digital mainloop: OWOut DQ, 1, [$CC, $44] ' Start temperature conversion waitloop: OWIn DQ, 4, [count_remain] ' Check for still busy converting If count_remain = 0 Then waitloop OWOut DQ, 1, [$CC, $BE] ' Read the temperature OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c] ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature) temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c) Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C" ' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature) temperature = (temperature */ 461) + 3200 Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F" Pause 1000 ' Display about once a second Goto mainloop ' Do it forever
Try this for Waitloop ...
AND ....Code:'***************************************************************************** ' Check for still busy converting ( ~ 4500 fois ... ) '***************************************************************************** waitloop: INPUT DQ If NOT DQ Then waitloop
Should be ...Code:DEFINE LCD_DATAUS 600
