How do I detect a polarity change on an input?
Results 1 to 22 of 22
    jessey's Avatar
    jessey Guest
    Default Your The Man!
    Very Clever Darrel,
    Thanks for the explanation and the code, I totally understand it now. It took me a few minutes to fully get it and once I did I could see with-out a doubt that it's fool proof.
    Thanks Again
    jessey
    Jessey, although your original query has been answered, I thought I would add my opinion as well.
    When you speak of the X10 transmitter I assume you are referring to an X10 RF transmitter, right?
    In which case, why not get rid of the X10 remote altogether, and drive an RF transmitter module directly with your 877? The RF protocol used by X10 is well documented (its actually the NEC IR protocol) and I could send you the URL(s). Besides the hardware being much simpler, you could send as many different commands and addresses as you wish without having to add more transistors.
    Anand
    Forgot to add, there are readymade basic snippets on the web that directly let a stamp drive an X10 firecracker as well; would achieve the same objective you seek.
    Anand
    jessey's Avatar
    jessey Guest
    Default Interesting idea
    Thanks Anand,
    I've been away visiting with a friend without a computer (hard to believe now a days). Now that's something that I'd definitely be interested in investigating. I surely would appericate receiving the URL's if you could please send them to me.
    Thanks Again
    jessey
    Hi Jessey,
    To begin with, here's Dave excellent page on the X10 RF protocol http://www.arkis.net/rf_protocol.htm.
    This would give you a pretty good starting point.
    The other approach would be to use a CM17A (Firecracker) module; this would eliminate the need for a separate RF transmitter. Theres loads of basic software available to drive it; one such page is at http://www.awce.com/firecracker.htm
    Hope this helps!
    Anand
    jessey's Avatar
    jessey Guest
    Default Thanks for the links
    Hello Anand,
    Thanks for the links, I've had some time now to ponder over the firecracker stamp code and have some questions if anyone can help me. I've never had any experience using the Stamp so it'll definitely be a learning experience for me. I ordered a firecracker and expect to have it in a week or so. It sure would be nice to be able to get rid of all the reed relays and transistors that I'm using now on my modified X10 remote control.
    I've checked the archives for any conversion tips for converting Stamp code to PBP and I did manage to find someone quoting that there are no NIB's in PBP so I changed all the NIB's to BYTE variables as the thread recommended.
    I also found that the stamp code didn't declare the port pins for the push buttons so I declared them as well. Another thing I did was to change the rts & dtr from CON statements to declaring them as port variables to enable setting them high and low in the PBP code for the transmitter (firecracker) and I'm also assuming that all I have to do for the ground of the transmitter is to tie it to the VSS of my 16F877.
    What I don't understand is that when I try to compile the code I get 3 errors:
    "error.macro and?bbl not found in macro file", is this some sort of an include file that I'm missing or something that I have to add or declare somewhere?
    Also I get two bad expressions, one for "READ housetbl+house,byt" and the other for "READ unittbl+(unit//8),tmp", is there a conversion for these two that will work for PBP? Could it be that the Data statement is wrong for PBP and possibly it needs an @ sign in there?
    Any help in understanding this code will be greatly appreciated.
    jessey
    '*  Name    : FIRECRACKER.BAS                               *
    '*  Author  : Jessey Montgomery                             *
    '*  Date    : Feb. 2nd, 2008                                *
    '*  Version : PBP ver 2.45, MicroCode Studio 2.1.0.7        *
    '*          : MPASM v03.60, EPIC Version 2.46 beta          *
    '*          : 16F877                                        *
    '*  Notes   :                                               *
    '                          |   16F877   |
    '         MCLR/Vpp ------> |1         40| <-----> RB7/PGD
    '          RA0/AN0 <-----> |2         39| <-----> RB6/PGC
    '          RA1/AN1 <-----> |3         38| <-----> RB5
    '    RA2/AN2/Vref- <-----> |4         37| <-----> RB4
    '    RA3/AN3/Vref+ <-----> |5         36| <-----> RB3/PGM
    '        RA4/TOCK1 <-----> |6         35| <-----> RB2
    '       RA5/AN4/SS <-----> |7         34| <-----> RB1
    '       RE0/RD/AN5 <-----> |8         33| <-----> RB0/INT0
    '       RE1/WR/AN6 <-----> |9         32| <-----  Vdd +
    '       RE2/CS/AN7 <-----> |10        31| <-----  Vss -
    '            + Vdd  -----> |11        30| <-----> RD7/PSP7
    '            _ VSS  -----> |12        29| <-----> RD6/PSP6
    '        OSC/CLKIN  -----> |13        28| <-----> RD5/PSP5
    '      OSC2/CLKOUT <------ |14        27| <-----> RD4/PSP4
    '  RC0/T1OSO/TICK1 <-----> |15        26| <-----> RC7/RX/DT
    '   RC1/T1OSI/CCP2 <-----> |16        25| <-----> RC6/TX/CK
    '         RC2/CPP1 <-----> |17        24| <-----> RC5/SDO
    '      RC3/SCK/SCL <-----> |18        23| <-----> RC4/SD1/SDA
    '         RD0/PSP0 <-----> |19        22| <-----> RD3/PSP3
    '         RD1/PSP1 <-----> |20        21| <-----> RD2/PSP2
    '-- Clear All The Variables And Each Port '
    '-- Before Setting The TRIS Registers     '
      Clear     ' Set all ram registers to zero
      PORTA = 0
      PORTB = 0
      PORTC = 0
      PORTD = 0
      PORTE = 0
    '-----------VSS VDD MCLR Ect. Pins -----------'
    ' MCLR         (Pin 1)
    ' VDD          (Pin 11)
    ' VSS          (Pin 12)
    ' OSC/CLKIN    (Pin 13)
    ' OSC2/CLKOUT  (Pin 14)
    ' VSS          (Pin 31)
    ' Vdd          (Pin 32)
     '-----------SET THE TRIS PINS BEING USED-----------'
     '-------------------- PORTA PINS --------------------'
      TRISA.0 = 1 '(pin 2) NOT USED
      TRISA.1 = 1 '(pin 3) NOT USED
      TRISA.2 = 1 '(pin 4) NOT USED
      TRISA.3 = 1 '(pin 5) NOT USED
      TRISA.4 = 1 '(pin 6) NOT USED
      TRISA.5 = 1 '(pin 7) NOT USED
     '-------------------- PORTB PINS --------------------'
      TRISB.0 = 1 '(pin 33) NOT USED
      TRISB.1 = 1 '(pin 34) NOT USED
      TRISB.2 = 1 '(pin 35) NOT USED
      TRISB.3 = 1 '(pin 36) NOT USED
      TRISB.4 = 1 '(pin 37) NOT USED
      TRISB.5 = 1 '(pin 38) NOT USED
      TRISB.6 = 1 '(pin 39) NOT USED
      TRISB.7 = 1 '(pin 40) NOT USED
     '-------------------- PORTC PINS --------------------'
      TRISC.0 = 1 '(pin 15) NOT USED
      TRISC.1 = 1 '(pin 16) NOT USED
      TRISC.2 = 1 '(pin 17) NOT USED
      TRISC.3 = 1 '(pin 18) NOT USED
      TRISC.4 = 1 '(pin 23) .......Pushbutton or input from LabXT
      TRISC.5 = 1 '(pin 24) .......Pushbutton or input from LabXT
      TRISC.6 = 1 '(pin 25) .......Pushbutton or input from LabXT
      TRISC.7 = 1 '(pin 26) .......Pushbutton or input from LabXT
     '-------------------- PORTD PINS --------------------'
      TRISD.0 = 0 '(pin 19) ........used to power the firecracker
      TRISD.1 = 0 '(pin 20) ........used to power the firecracker
      TRISD.2 = 1 '(pin 21) NOT USED
      TRISD.3 = 1 '(pin 22) NOT USED
      TRISD.4 = 1 '(pin 27) NOT USED
      TRISD.5 = 1 '(pin 28) NOT USED
      TRISD.6 = 1 '(pin 29) NOT USED
      TRISD.7 = 1 '(pin 30) NOT USED
     '-------------------- PORTE PINS --------------------'
      TRISE.0 = 1 '(pin 8)  NOT USED
      TRISE.1 = 1 '(pin 9)  NOT USED
      TRISE.2 = 1 '(pin 10) NOT USED
    DEFINE OSC 4         ' 4MHz crystal
    @ __CONFIG _HS_OSC &_BODEN_OFF &_PWRTE_ON &_WDT_ON &_CP_OFF
    &_LVP_OFF
    ' turn off the Crossing page boundary warnings
    @ errorlevel -306
     ADCON1 = 7   ' Set PORTA and PORTE to digital
    ' This is a link to the orginal code below,
    ' http://www.awce.com/firecracker.htm
    ' Define Variables Here
    ' byte to send
     byt var byte
     tmp var byte
     i var BYTE 'was a nib
     x var BYTE 'was a nib
     state var bit(4)
     house var byte '0=A 1=B...
     unit var BYTE  ' 0-15  (must be 0 for bright/dim) 'was a nib
     cmd var BYTE  ' 0=off 1=on 2=bright 3=dim 'was a nib
    'these push buttons weren't declared
     in11 VAR PORTC.4 ' (pin 23)..Pushbutton or input from LabXT
     in10 VAR PORTC.5 ' (pin 24)..Pushbutton or input from LabXT
     in9  VAR PORTC.6 ' (pin 25)..Pushbutton or input from LabXT
     in8  VAR PORTC.7 ' (pin 26)..Pushbutton or input from LabXT
    ' Firecracker Interface (Al Williams)
    ' http://www.al-williams.com/awce
    ' Wire Ground (DB9 pin 5)
    ' DTR (DB9 pin 4)
    ' RTS (DB9 pin 7)
    'rts con 1
    'dtr con 0
    rts VAR PORTD.0 ' pin 19
    dtr VAR PORTD.1 ' pin 20
    ' The Firecracker header (2 bytes)
    h1 con $D5
    h2 con $AA
    ' the Firecracker footer (1 byte)
    foot con $AD
    gosub resetfirecracker
    ' Sample program
    ' all off
      for x=0 to 3
        house=0
        unit=x
        cmd=0
        gosub sendcmd
        pause 20
        state(x)=0
      next
    mainloop:
      if in11=0 then c0  ' look for buttons on p8-11
      if in10=0 then c1
      if in9=0 then c2
      if in8=0 then c3
      goto mainloop
    c0:
      x=0
      goto ccmd
    c1:
      x=1
      goto ccmd
    c2:
      x=2
      goto ccmd
    c3:
      x=3
    ccmd:
      unit=x
      cmd=state(x)+1
      if cmd=1 then gocmd
      cmd=0
    gocmd:
       gosub sendcmd
       pause 250
       state(x)=cmd
       goto mainloop
    ' End of example program
    ' Send command
    sendcmd:
      byt=h1
      gosub sendbyte
      byt=h2
      gosub sendbyte
      read housetbl+house,byt
      if unit<9 then lowunit
      byt=byt+4
    lowunit:
      gosub sendbyte
      byt=$20
      if cmd=0 then addunit
      byt=0
      if cmd=1 then addunit
      byt=$88
      if cmd=2 then nounit
      byt=$98
      if cmd=3 then nounit
    ' huh???
    addunit:
      read unittbl+(unit//8),tmp
      byt=byt+tmp
    nounit:
      gosub sendbyte
      byt=foot
      gosub sendbyte
    ' Send 1 raw byte
    sendbyte:
      debug hex byt," "
      for i=0 to 7
       if byt & $80 = $80 then xmit1
       gosub send0
    nextbit:
       pause 1
       byt=byt*2
       next
    ' Send a 1
    xmit1:
      gosub send1
      goto nextbit
    ' Send bits (0 or 1)
    send0:
      low rts
      pause 1
      high rts
    send1:
      low dtr
      pause 1
      high dtr
    ' Always reset firecracker first
    resetfirecracker:
    low rts
    low dtr
    pause 50  ' reset
    high rts
    high dtr
    pause 50
    ' Data for house and unit codes
    ' should there be an @ somewhere below for pbp?
    housetbl data $60,$70,$40,$50,$80,$90,$A0,$B0,$E0,$F0,$C0,$D0
          data $00,$10,$20,$30
    unittbl data 0,$10,$8,$18,$40,$50,$48,$58
    Hi Jessey,
    Can't comment on the FireCracker thingy, but I beleive the and?bbl problem is in the
    &nbsp; &nbsp; if byt & $80 = $80 then xmit1
    Statement.
    Putting parenthesis around the bitwise AND should fix it.
    &nbsp; &nbsp; if (byt & $80) = $80 then xmit1
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. Replies: 1
    Last Post: - 7th November 2007, 20:36
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. detect oscillating input
    By fester addams in forum General
    Last Post: - 22nd November 2004, 18:08
