On Interrupt & Gie
Results 1 to 3 of 3
    Default On Interrupt & Gie
    Hi
    Suppose that I want to disable interrupts after ON INTERRUPT command.
    I read below suggestion in a book:
    We shuldn't disable interrupts after ON INTERRUPT command with clearing GIE because
    clearing this bit declares to PBP that an interrupt's happened and PBP jumps to ISR.
    Instead of above we should use INTCON=%10000000
    IS it True? Why?
    Regards.
    Hi yasser,
    It's half right, and the solution is half wrong.
    When using ON INTERRUPT, you can not "Disable" the interrupts by clearing the GIE bit. Clearing GIE tells PBP that an interrupt has occured.
    In suggesting INTCON=%10000000, perhaps they were only considering the peripheral interrupt sources. Which means the global interrupts can still trigger.
    For ON INTERRUPT, If you want to make sure interrupts can't happen in a section of code, you need to wrap DISABLE / ENABLE statements around the affected code.
    Doing so also reduces the "Code Bloat" from checking interrupts in-between each and every line of code.
    Default Thanks
    Hi dear Darrel Taylor
    Thank you very much for your really helpful reply.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
