Writing internal calibration value
Results 1 to 7 of 7
    Default Writing internal calibration value
    Hi all,
    In all 12F675 pics the internal oscilator calibration value is written inside the pic and every time we save a new program ( with IC-prog for example ) we have to choose NOT to overwrite it's value.
    I know that this value is different for each pic but when testing new code we have to re-program the same pic over and over again.
    My question:
    Is it possible ( and how ) to include in pbp's code the value so that IC-prog ( or any other ) adds the cal value ?
    I think this may be what you are looking for.
    http://www.picbasic.co.uk/forum/show...SCCAL+register
    Thanks mackrackit,
    With the link i found that i need to use the line:
    POKECODE @$3FF, $78 ( where $78 should be replaced with my setting )
    When using this with my pbp i get alot of error lines like :
    [218] Address limit of 3FFh Exceeded
    Did i miss something ?
    Quote Originally Posted by ruijc View Post
    Thanks mackrackit,
    That should work.
    What value do you have when you read 3FF?
    the pic's original value is 74.
    POKECODE @$3FF, $74 has to be the very last line of code. If you try placing this before
    anything else PBP thinks you're out of code space.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks Bruce,
    I believe you are right !
    It makes perfect sense !
    This line should be the last line ( i did actually placed on top next with the settings ).
    Will try this when i get home.
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. 12F683 internal pull up
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th July 2008, 02:35
  3. Writing, Reading from Internal PIC EEPROM
    By NO2K in forum mel PIC BASIC Pro
    Last Post: - 4th October 2007, 00:35
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
