Return VS Goto?
Results 1 to 7 of 7
Thread: Return VS Goto?
    weird, it works here, none hangs. Maybe it has something to do with the on-board programmer.
    Make sure it program & update the configuration fuses.
    The minimum you need is XT_OSC and LVP_OFF and make sure you crystal jumpers are correctly set.
    which software are you using to program your pic with the Velleman kit? (WinpicProg, ic-prog or else?)
    did you tried their update?
    http://www.velleman.be/downloads/fil...update_2_6.zip
    Jan 2008
    Talking
    I use Velleman Progpic2 with the update installed..
    I just reprogrammed the PIC with the "RETURN" code and now it works.. weird???
    Maybe there is something wrong with my programmer?
    Anyway it work´s now..
    Thanx for a great forum.
  1. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 19:54
  2. Replies: 14
    Last Post: - 26th September 2007, 05:41
  3. Comm example: Pic to Pic
    By Chadhammer in forum Code Examples
    Last Post: - 14th November 2006, 23:26
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
