Return VS Goto?
Results 1 to 7 of 7
Thread: Return VS Goto?
    Both code chunks are essentially identical (with the obvious RETURN vs GOTO exception), and both should function equally well (aside from the obvious program flow differences).
    Do you have a pullup/pulldown resistor on PortB.0?
    What's connected to MCLR?
    Jan 2008
    The PIC is on a Velleman K8048 Programmer and Experiment board.
    http://www.velleman.be/ot/en/product/view/?id=350903
    Yes i have a pull up resistor..
    If the code is identical why does it hangs with the first code?
    weird, it works here, none hangs. Maybe it has something to do with the on-board programmer.
    Make sure it program & update the configuration fuses.
    The minimum you need is XT_OSC and LVP_OFF and make sure you crystal jumpers are correctly set.
    which software are you using to program your pic with the Velleman kit? (WinpicProg, ic-prog or else?)
    did you tried their update?
    http://www.velleman.be/downloads/fil...update_2_6.zip
    Jan 2008
    Talking
    I use Velleman Progpic2 with the update installed..
    I just reprogrammed the PIC with the "RETURN" code and now it works.. weird???
    Maybe there is something wrong with my programmer?
    Anyway it work´s now..
    Thanx for a great forum.
    Quote Originally Posted by Fredrick View Post
    Pull up resistor on MCLR?
    What about PortB.0?
    If you've got nothing on it, it might be floating and confusing your program somehow.
    As far as the identical goes, what I meant was 'functionally identical', I didn't mean identical as in 'the same' or 'equal'.
    And I don't know why.
    If it works with the 2nd code, go with it.
  1. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Comm example: Pic to Pic
    By Chadhammer in forum Code Examples
    Last Post: - 15th November 2006, 00:26
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
