Rfid Reader- Pic
Results 1 to 10 of 10
    Quote Originally Posted by cleas001 View Post
    yes ive got basic knowledge of programming and ive got all that equuipment avialiable should i need it
    you mention about the serial port? is this to conect to computer? - i do not wish to conect my device to a computer- is there a way in which the PIC an process the information to display on the LCD - withouht having to go through a serial port?
    These 2 statements seem to conflict.
    How much MCU programming have you done? Not Windows, not Visual Basic, actual MCU programming, at the binary/hex level?
    Reason I ask is that if you are somewhat knowledgable in this area, then you would know that a fair share of PICs out there have built in UART specifically for external serial access, and those that don't are able to obtain external serial access by means of software emulation through PicBasicPro (or other compilers out there).
    Jan 2008
    hello thanks for all the help so far
    in answer to your question i have so far been doing my programming in mplab - so i knowledge of the programming methods and languages in that.
    I suggest to read again the answers especially #5 word by word. It is explained that PIC can do serial rs-232 either in hrdware or in software. To succeed in this project you have to read a lot the data sheets of the pic you are going to use and the manual of the PBP that obviously you have not so far. Please, please search and read. All info's are in front of you. It is easy project, you have all the resources, so do it!
    If your code is not working we are here to check it out. But don't expect to write it for you... Unless you pay for it! $-)
    Aug 2003
    Someone's gone to a lot of trouble to make a program that should be one or two hundred lines
    about one or two lines.
    Two lines is about all it is in the main routine if I remember.
    The serin command that has a "wait" option, and the LCDOUT command.
    Those two lines wrapped in a loop is your program.
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 22:16
  2. how synchronize with rfid reader
    By karellen in forum Serial
    Last Post: - 6th December 2009, 15:13
  3. Proximity Reader (Weigand) aka RFID
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2009, 05:41
  4. Replies: 3
    Last Post: - 12th March 2008, 05:33
  5. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
