Rfid Reader- Pic
Results 1 to 10 of 10
    Jan 2008
    Default Rfid Reader- Pic
    hello-
    i wish to connect a RFID reader to a PIC and then to a LCD so that i can display the TAG IDs.
    However i am completly stumped when it comes to connecting this set-up ( as i am reasonibly new to the world of electronics) - the reader which i currently have is a core- 12
    http://www.rfidshop.com/core-12-rfid...dule-110-p.asp
    do you know if this is possible?
    do i require additional hardware?
    how can this be done?
    help with any of these would be gratefuly appreciated thank you
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by cleas001 View Post
    Yes, the PIC can do it. Yes, PBP will be very useful.
    Yes, if you are completely stumped as to how to connect this setup and you are new to the world of electronics, you are most definetely in over your head. Quite frankly, this is a simple project, for an experienced person anyways.
    But, don't let that rant stop you in the least.
    What kind of equipment do you have, if any? Programmer? Dev Board? Compiler, etc?
    What experience, if any, do you have, programming PICs, or any MCU for that matter?
    Made any blinky LEDs or anything like that?
    Jan 2008
    yes ive got basic knowledge of programming and ive got all that equuipment avialiable should i need it - im just confued by the data sheet supplied with the reader - as to which pins i would need to connect the PIC towould these be the 2 free data lines?
    skimask's Avatar
    skimask Guest
    Looks like pin 9 (ASCII out, TTL) to me, just like the datasheet says.
    The core-12 reader has a serial output at TTL level. So it is a piece of cake to connect and start getting data into your PIC. PBP supports Serial protocol (RS-232) either in software or in hardware. I recommend the second using Hserin command if your PIC has a UART. Note that you need to put a MAX232 chip. The core-12 has inside it an inverter. If you are going to use a PIC with no UART, then use Serin2 command with invert parameters.
    Every time you cross a card over the reader, a stream of ascii data are output of the core-12. Have your PIC read the stream into an array and you are done.
    More about syntax, examples etc, put the words that you just read into the search of this forum. You will find everything on Serial ports, LCD, ASCII, and us here when you write your code that obviously is not going to run first time! 8-)
    Jan 2008
    hello
    you mention about the serial port? is this to conect to computer? - i do not wish to conect my device to a computer- is there a way in which the PIC an process the information to display on the LCD - withouht having to go through a serial port?
    the type of LCD i mean is one like this: http://www.maplin.co.uk/Module.aspx?...6389&criteria=
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 22:16
  2. how synchronize with rfid reader
    By karellen in forum Serial
    Last Post: - 6th December 2009, 15:13
  3. Proximity Reader (Weigand) aka RFID
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2009, 05:41
  4. Replies: 3
    Last Post: - 12th March 2008, 05:33
  5. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
