BrianT, sinoteq,
thanks alot for the help.
Actually it's not just the first character but 90% and most of the time 100% of the entire first line .
As a note, i'm using a direct connection from the pic to the serial port.
Also tryed using an 1K resistor between I/O and serial port but the result is the same.
With your experience...what is best ? To use the serial resistor or not ?
Will try your instructions tonight
I never connect my things without level-converter. It is so easy to make, really cheap so I don't see why not use it.
