problem of LOW voltage on USB ports of Intel 915GLVG mobos
Results 1 to 7 of 7
    yeah sure the on-board USB have a current sensor, not sure if a PCI card have it... if so, how better worst it is? I'll measure it here.
    As Darrel says, an external powered USB hub 'may' solve the problem. i don't get your point of auto-detection...
    But for sure, there's a current limiting somewhere, XP should warn you in case you overload it.
    EDIT: Measurement done here...
    My HP machine
    Load 5 Ohm..
    On board USB - 4.26 volts,
    PCI Cards 4.1 volt
    My intel machine
    On-Board 4 volt
    Mar 2006
    Hyderabad (India)
    My HP machine
    Load 5 Ohm..
    PCI Cards 4.1 volt
    My intel machine
    On-Board 4 volt
    Sir, please see the pdf form Intel titled "Power Delivery Design Issues for Hi-Speed USB on Motherboards" i got it from www.usb.org please try to put the article title on google , you land straight on the location .
    Sarma
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  2. "hello world" with 18f6680
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 6th February 2008, 06:06
  3. Microcontroller with 2 way paging application problem
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
