problem of LOW voltage on USB ports of Intel 915GLVG mobos
Results 1 to 7 of 7
    An easy fix might be to use a "Self-Powered" USB HUB.
    Usually they have a DC "Wall Wart" to provide power for more devices.
    Mar 2006
    Hyderabad (India)
    I get your point, but the facility of USB auto detection will not ne anymore effective, I am told.
    Instead i can take power from one of the spare connectors of the SMPS of the PC itself.as it is measuring 5.14V approx.
    Sarma
    i'm curious to know how much current all USB device connected needs and how much your actual PSU can provide. Seems like a current protection, unsufficient or 'about to fail' psu to me.
    Check if your mother board have a Jumper for USB power. some allow you to change from Vusb to 5V (more specific term... but i never remind which one)
    EDIT: I've look to you Mobo manual.. yours don't seems to have that USB power source jumper
    Mar 2006
    Hyderabad (India)
    Mine is arond 2 years old PC. I made a check of the situation. the actual %V DC is right at 5.12V at many load points. At the same time the USB derived voltage is around 4.44V or even 3.84V at times. I initially suspected SMPS. But it is OK.
    I fear the supply to USB is given in series to any sensor for the current and thus the sensing element drops across it. I wonder, whether the internal structure of Intel USB driver chip is to be studied.
    Sarma
    yeah sure the on-board USB have a current sensor, not sure if a PCI card have it... if so, how better worst it is? I'll measure it here.
    As Darrel says, an external powered USB hub 'may' solve the problem. i don't get your point of auto-detection...
    But for sure, there's a current limiting somewhere, XP should warn you in case you overload it.
    EDIT: Measurement done here...
    My HP machine
    Load 5 Ohm..
    On board USB - 4.26 volts,
    PCI Cards 4.1 volt
    My intel machine
    On-Board 4 volt
    Mar 2006
    Hyderabad (India)
    My HP machine
    Load 5 Ohm..
    PCI Cards 4.1 volt
    My intel machine
    On-Board 4 volt
    Sir, please see the pdf form Intel titled "Power Delivery Design Issues for Hi-Speed USB on Motherboards" i got it from www.usb.org please try to put the article title on google , you land straight on the location .
    Sarma
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  2. "hello world" with 18f6680
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 6th February 2008, 06:06
  3. Microcontroller with 2 way paging application problem
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
