Proton PICBASIC vs MeLabs PICBASIC
Results 1 to 23 of 23
    Dec 2005
    mikroBasic for PIC is another procedural basic. It's very advanced in some areas (e.g. handling interrupts), less so in others. It has a ton of libraries although they tend to be 18F oriented. It's worth investigating if you're trying to decide on a PIC development language. It costs less than PBP and you don't need a license for apps that are smaller than 2K.
    Feb 2003
    Sydney, Australia
    I have a copy of MikroBasic, but find it frustrating that it does not have equivalents to SerIn2 command with time-outs if there is no data. So for any serial you need to write an interrupt routine otherwise the serial receive is a blocking command...
    But on the other hand it does support GLCD, Ethernet parts and CF or SD Cards out of the box.
    bill
    Italy
    Quote Originally Posted by bcd View Post
    Hi Bill,
    I have never used the MikroBasic compiler but after a quick
    look at the PDF manual I have a solution for your software UART
    timeout problem.
    Best regards,
    Luciano
    From page 257 of MikroBasic for Pic.
    (This is the original sample code).
    ' Here's a loop which holds until data is received:
    error = 1
    do
      data = Soft_Uart_Read(error)
    loop until error = 0
    Here is a version with timeout using BREAK to exit the Do loop:
    ' or the timeout value has reached 10000.
    Dim MyTimeOutCounter as longint
    Dim MyError as byte
    Dim MyData as byte
    MyError = 1
    MyTimeOutCounter = 0
    Do
      MyData = Soft_Uart_Read(MyError)
      MyTimeOutCounter = MyTimeOutCounter + 1 ' increment our timeout counter
      If MyTimeOutCounter = 10000 Then ' you will have to adjust this value
         Break  'Exit the Do Loop
      End if
    Loop until MyError = 0
    If MyError = 0 Then ' Optional IF
      ' Serial transfer was successful
    Else
      ' Timeout occured
    Endif
    Dec 2005
    But writing an interrupt routine is a piece of cake and examples are easy to find - I think they are even included.
    Sep 2007
    USA, CA
    I don't use Mikrobasic, but here is an easy way to do it without interrupts...just translate the code to proper syntax. (And set the symbols of cTxReg etc. to the appropriate values. Leading characters are: c=constant, b=byte.)
    bDelayTime = 0
    CheckForData:
    if cTxReg = cDataWaiting then 'check hardware Tx register for incoming data.
    serin = bSerialDataIn 'get data...
    goto SerialDataReceived
    else 'no data waiting...
    pause 1 'wait 1ms...change to match your baud rate, since some speed may overwrite
    bDelayTime = bDelayTime + 1
    if bDelayTime = cMaxWaitTime then
    goto NoSerialDataReceived
    goto CheckForData
    Sep 2007
    USA, CA
    For those wanting to do it with interrupts, do a quick search for "buffer" on the Proton forum. ( http://www.picbasic.org/forum/ ) Les, the PDS author, wrote a subroutine for 18F's to buffer all incoming serial data. It should be possible (given enough ingenuity) to convert it to PBP or Mikrobasic.
    Dec 2005
    For those wanting to do it with interrupts, download the Soft Uart for P12 by Warren Schroeder project from http://www.mikroe.com/en/projects/
    It's an excellent tutorial as well as an interrupt driven full-duplex software UART. The code is quite simple and easy to follow.
    Italy
    Full-duplex software UART is not possible or possible only if the baud rate
    is very low and interrupts are used. (Software UARTs use bit-banging).
    Soft Uart for P12 by Warren Schroeder:
    If you look at the code you will see that RX uses an interrupt and that in
    the SUB TX_19200 interrupts are disabled. This means that while
    you are sending data you cannot receive data at the same time. (Not Full-duplex).
    Best regards,
    Luciano
    Italy
    Quote Originally Posted by tenaja View Post
    bDelayTime = 0
    CheckForData:
    goto CheckForData
    Your code does not work with software UARTs.
    Software UART routines use bit-banging techniques and can use almost any I/O pin
    of the microcontroller. Software UARTs have big limitations and if the microcontroller has
    hardware UARTs just use them!
    Best regards,
    Luciano
    Sep 2007
    USA, CA
    Quote Originally Posted by Luciano View Post
    This is absolutely true.
    Sep 2007
    USA, CA
    One nice thing about Proton+ is in the forum, Les the compiler author occasionally posts misc. PDS code. (In addition to helping out on the forum when needed.) For instance, he's posted a full Space Invaders game that works with the Crownhill development board... which is modeled in the VSM simulator so you can play it right on your PC screen (or the actual development board).
    He's also posted code to use as a serial buffer for the hardware usart, so it will receive data in the background, and fill it in when you get around to using a hserin command. More examples are speech decompression routines, and a full .wav file player design with CF FAT and audio out routines.
    These are just a few examples. Some of them can easily be ported to PBP; others may take some work.
  1. PICBasic Pro vs. Proton Dev System
    By hjsong in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 05:17
  2. PICBasic Pro vs Proton PICBasic
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 17:11
  3. help me Proton PICBASIC version compl
    By samirouf in forum mel PIC BASIC
    Last Post: - 1st May 2005, 20:25
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. Proton development board with Picbasic
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 25th July 2004, 23:19
