Array problem (18F2550)
Results 1 to 3 of 3
    Sep 2007
    Default Array problem (18F2550)
    I use the 18F2550
    The configuration settings of my application are arranged in de Eeprom of the PIC. At the beginning of my application the complete Eeprom information is copied (read) to an Array (255).
    Part of my application
    DATAEEPROM VAR BYTE[255]
    I var byte
    I=0
    FOR I=0 TO 255
    READ I,DATAEEPROM[I]
    NEXT I
    I found out the the information in DATAEEPROM[0] is always 0. However the data at this position is 255 (FF). I found out the location 0 of the Array is causing the problem.
    when I change
    to
    READ I,DATAEEPROM[I+1]
    however then I'll get problems with the last position.
    Does somebody knows what I'm doing wrong?
    i+1 will give 256, which is almost impossible to fit in a byte variable, even if you bend the edges of it maybe 0+i could work better. Even with it... you defined a 255 bytes array while your read 256 value. you should define a 256 bytes array size.
    Out of curiosity, why are you using an array to hold the whole EEPROM ?
    Sep 2007
    I do that because I think that accessing information with an array is quicker than than accessing information of the PIC eeprom. I have not found information whether I'm right or wrong.
    Within my application (PLC) information from the eeprom is read into a var more than 1000 times per second. I thought the application will be faster to use an Array for this.
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  2. 18f2550 USB OSC Problem
    By serkanc in forum USB
    Last Post: - 29th October 2008, 21:52
  3. Problem with A port on 18F2550
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 9th May 2007, 23:59
  4. array problem
    By ro37bis in forum mel PIC BASIC Pro
    Last Post: - 16th September 2006, 22:12
  5. Problem with bit array
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 12th May 2005, 18:03
