LED Tach Sources?
Results 1 to 7 of 7
Threaded View
  1. #3
    well,
    as i understand you want to use these bar to display an Variable value. Which kind of display you need. Full bar or only 1 led at the time ???
    I assume you'll use full bar display. In this case you can use serial shift register in cascade to give you all outputs pins you need and use an trivial serial output to them. this should work as you wish. or, more simple use PIC16F871 with up to 33 i/o lines.
    regards
  1. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  2. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  3. For next loop using: Led var Byte
    By quester in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:16
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
