robot program
Results 1 to 3 of 3
Thread: robot program
    Jan 2006
    Istanbul
    Usually, you won't get replies for this kind of request.
    I am on my good day t0day!
    b0 var byte
    b1 var byte
    b2 var byte
    start:
         pot 1, 255,b0   'Read CdS cell # 1
         pot 2, 255,b1   'Read CdS cell # 2
         If b0 = b1 then straight
         if b0 > b1 then left
         if b1 > b0 then right
    straight:
         high 3
         high 4
         goto start
    left:
         b2 = b0 - b1          'Compare numerical values +/15
         if b2 > 15 then left1 'If greater than 15 turn left
         goto straight         'If not go to straight subroutine
    left1:                     'Turn left
         high 3
         low 4                 'Motor control
         goto start
    right: 'Compare numerical values +/15
         b2 = b1 - b0           'If greater then 15 points
         if b2 > 15 then right1 'Turn toward the right
         goto straight          'If not go straight
    right1:                     'Turn right
         high 4
         low 3                  'Motor control
         goto start 'Do again
    Now, at least, you should be able to say what your mistake was.
    Can you?
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
