HPWM10 Frequency Updating
Results 1 to 18 of 18
    Default HPWM10 macro
    I need a ten bit HPWM so I searched for "HPWM10 macro" as mentioned in the prior post.
    No joy.
    Here is the error message.........
    Did you mean: HPM 10 macro
    No standard web pages containing all your search terms were found.
    Your search - HPWM10 macro - did not match any documents.
    Suggestions:
    Make sure all words are spelled correctly.
    Try different keywords.
    Try more general keywords.
    Try fewer keywords..........
    Where can I find a 10 bit HPWM command?
    Cheers
    BrianT
    I'd like to be able to explain the search engines..... but I can't.
    Good thing there's People around.
    https://www.picbasic.co.uk/forum/showthread.php?p=37805
    Sep 2005
    Campbell, CA
    The code that I posted does a 10bit HPWM.
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    Glitch Free to 500khz ?
    Yeah, mine neither.
    Sep 2005
    Campbell, CA
    A PIC can't do 10 bit PWM to 500Khz, since it would need a counter running at 500KHz * 1024 = 512MHz.
    Charles Linquist
    Absolutely Correct!
    As the frequency increases, the resolution decreases.
    Follow that all the way to the highest frequency, and with OSC=16, you should have 2mhz PWM at 1-bit resolution (essentially on or off).
    @ 500 khz, you should have 4-bits. And if all you ever want is 50% dutycycle, then it's a piece of cake.
    Default 10 bit HPWM at 32767 Hz
    Hi Darrel & Charles.
    I need 50% duty cycle at 32767 Hz on CCP2 to drive an Intersema pressure sensor - easy - even I can do that with 8 bit HPWM.
    I also need a variable duty cycle to drive an AGC circuit. With 8 bit HPWM, my AGC is sudden death and one count goes from not quite enough to a little bit too much. 10 bit HPWM would be much less sensitive. The frequency must stay at 32767 Hz to suit the Intersema sensor.
    Can I get 10 bit HPWM at 32767 Hz?
    Cheers
    Brian
  1. Advice on frequency measurement to 30MHz
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 04:23
  2. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 22:41
  3. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
  4. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 00:53
  5. Low frequency output
    By barkerben in forum General
    Last Post: - 16th November 2004, 15:25
